Brake and battery coolant fluid
Discussion in 'Model S' started by MsElectric, Nov 7, 2014.
Tags:
  1. MsElectric
    MsElectric Active Member
    New York
    Just curious to see what the recommended maintenance interval is for the brake fluid in the Model S. Does that fluid need to be flushed/replace every certain number of miles? How does this pertain to the new electric brake system. Is that all electric but with a hydraulic backup?
    It seems other than the brake system and the battery coolant system there are no other fluids to be serviced right? Is the battery coolant fluid ever replaced/changed?
  2. TES-E
    TES-E Member
    Casa Grande, AZ
    I would think that the single speed gearbox would need to have the oil changed at some point.
  3. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Most brake fluids are hygroscopic, which means they absorb moisture. Over time they get "wet" which significantly reduces their boiling temperature. As such, brake fluid should be changed every two years.
    Unless of course Tesla anticipated the potential of people never bringing their cars in for service and went with a non-hygroscopic fluid (rare). Would be interesting to find out.
  4. gavine
    gavine Petrol Head turned EV Enthusiast
    Philadelphia, PA
    I read somewhere that this fluid needs to be changed every 15 years.
  5. breser
    breser AutoPilot Nostradamus
    North Bend, WA
    The new electromechanical braking system is still hydraulic, it just replaces the vacuum assist with a electromechanical assist. So yes you still have brake fluid. Tesla recommends that brake fluid be replaced every 2 years/25,000 miles/40,000 km.
    Tesla recommends this be replaced 4 years/50,000 miles/80,000 km.
    Tesla recommends the transmission fluid be replaced every 12 years/150,000 miles/240,000 km.
    Source for all these numbers.
  6. MsElectric
    New York
    Wow you know what you are talking about :) Thanks for such well searched information! So it seems with major Tesla maintenance we are looking at:
    + Brake fluid every 2 years (25K miles)
    + Battery coolant every 4 years (50K miles)
    + Transmission fluid every 12 years (150K miles)
    Any other major fluid flushes/changes or other major service items I am missing other than small things like cabin air filter, wipers, etc., ?
    So how does Tesla charge for these services? It seems odd they have a fixed yearly service fee when it seems the best thing to do it is to take in every 2 years as that will get you the brake fluid change and the battery coolant fluid change...
  7. jerry33
    Texas
    I'd be wary of this one unless someone has a lab report on the fluid and how it changed as miles accumulated. If there is exposure to air (from thermal expansion/contraction via some kind of vent) dust will get in and shorten the life significantly. In the Prius, lab analysis indicates that after 40,000 miles there is significant degradation of the PSD fluid. (Toyota has no change interval for the PSD fluid).
  8. dave
    dave Member
    Greater Cincinnati
    I'm thinking of getting Tesla to do just the brake fluid this year instead of the full inspection (I do my own tires, wiper blades, etc). Has anyone else done this? Do you know what they charge?
  9. apacheguy
    apacheguy S Sig #255
    So Cal
    In they grand scheme of things those are probably the minor servicing needs of the MS. And if you pay for service either a la carte or thru a service plan, they're already included. Major service items would be a master charger or touchscreen failure out of warranty. It has happened and, no, owners were definitely not happy to be forking over several grand for a "low maintenance" EV.
  10. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    2 years on brake fluid? I've gone 15 in my last car with only ever topping it off.
  11. scottm
    scottm Legacy account
    Canada
    Stop much?
  12. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    From the Tesla Manual
    Warning:
    Contact Tesla immediately if
    you notice any significant or sudden drop
    in fluid levels or uneven tire wear.
    Fluid Replacement Intervals
    Do not change or top up Battery coolant and
    brake fluid yourself. Tesla service technicians
    replace fluids at the regularly scheduled
    service intervals:
    • Brake fluid. Every 2 years or 25,000 miles
    (40,000 km), whichever comes first.
    • Battery coolant. Every 5 years or
    62,500 miles (100,000 km), whichever
    comes first.
    Note:
    Any damage from opening the Battery
  13. apacheguy
    So Cal
    Something changed there. I've seen one of the inspection sheets that they use when completing annual service. Battery coolant definitely used to be replaced every 4 or 48,000 miles.
  14. marchyman
    marchyman Member
    San Mateo, Ca
    Brake fluid is hygroscopic. When the absorbed moisture hits about 4% of the total volume the fluid needs to be replaced unless you like the idea of brake fade due to the presence of air bubbles from water boiling out at the high temperatures that can be generated in brake use. How long it takes to hit 4% varies depending upon where you live. 2 years is a safe number. Another choice is to buy one of these (assuming the Tesla uses DOT 4) and change when needed.
  15. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    The brakes don't fade, they lock up!
  16. marchyman
    marchyman Member
    San Mateo, Ca
    The typical failure mode is the formation of vapor pockets when the fluid gets too hot. The vapor displaces fluid (which can cause lock-up, but not always). Vapor is compressible. When brakes are applied the pedal may go all the way to the floor (compressing the vapor) without applying the brakes! Brakes can also lock up if the water content is enough to cause corrosion of internal parts and left to sit for a while. That is sometimes a cause of expensive ABS unit failures in my motorcycle experience.
  17. SabrToothSqrl
    PA
    Only 285,000 miles worth of stopping.
  18. DFibRL8R
    DFibRL8R Active Member
    Leesburg Virginia
    The current Model S manual now says "Battery coolant: Every 8 years or 100,000 miles (160,000 km), whichever comes first." Interesting that the interval recommendation has changed for the better (less maintenance required).
  19. SabrToothSqrl
    PA
    lol, that's like BMW telling you, you can go 15,000 on an oil change. Not sure it's for the better... but again I'm not worried 'bout it.
