So my MS is in for service (fourth annual). I have the prepaid service plan. The service center in Rockville recommended to have a brake cleaning done which would run me $75. They say because the brakes are used infrequently it would be important to clean and lubricate them. I asked why that would not be included in the service plan as it would seem a typical maintenance item but was told it is not.
What do you all think?
Love it, this is exactly the sort of thing people hate from traditional car dealers, and what Tesla claimed they wouldn't be doing.
They have raised the price for brake cleaning to $150.
On RWD vehicles that would only apply to rear wheels, so an AWD vehicle has twice the labor
.Brake Caliper Pad Slides
Note: This is recommended for cold weather regions.
Note: Cleaning and lubricating the caliper pad slides/abutments is not included in the Annual Service price.
Note: Perform the following steps on all 4 calipers.
- Remove the pad retaining pins and collect the anti-rattle spring.
Note: Always check that the anti-rattle clip has not been damaged. This part is easily damaged and is important to help eliminate squeaks.
Front caliper Rear caliper
- Use a suitable tool to gently push the pistons back into caliper.
- Remove the brake pads from the caliper.
- Thoroughly clean the caliper pad slides and abutments with a hand brush (1057223-00-A) and soapy water.
Caution: If there is rust or pitting on the caliper that cannot be removed with a hand brush, replace the caliper.
- Front brake caliper (refer to procedure).
- Rear brake caliper (refer to procedure).
- Apply an even layer of Silaramic lubricant (1063021-00-A) to the caliper pad slides. Remove any excess lubricant.
- Apply an even layer of copper paste between the shim and the backing plate. Remove any paste that squeezes out after installing the shim.
Caution: Ensure that the brake pads move freely.
Caution: Do not apply copper paste to the caliper, seals, or any component other than the shim and backing plate.
Here's what I do when I switch over wheels to the other season...
when the wheel is off, knock out the two pins on the caliper
pull the pad out (it is just slotted in from the outside edge of the caliper)
clean the sides of the pad with a file
clean the sides of the slot in the caliper, with a little square file
put a little bit of anti-seize compound on the side edges of the pad
slot the pad back into the caliper
put the pins in
this takes about 10 minutes per wheel, this is so easy to do with these brakes
So no cleanup on the pistons. Since you're right up close to them when you do this -- do you see any corrosion that makes you think eventually they'll need it?
