In my never ending quest to ensure my pads and rotors last and perform optimally, I pursued installing brake cooling ducts.
In preliminary testing, I found that removing the braking plate from the front reduced rotor temperatures by roughly 20%. However, this exposes the ABS sensor to extreme heat and is not an ideal solution. By utilizing a brake ducting system to force-feed air into the front rotors, this brake cooling kit will not only prevent boiling fluid and pedal fade, but it can drastically reduce pad and rotor wear as well.
For this project, I chose 3" Tubing with 3" Brake Ducts and Flanges. However, there is not a lot of room to work with. It required re-routing/re-securing coolant lines and A/C lines to get the ducting to fit. That being said, it does work! It may make more sense for most people to look into 2" hardware.
I do still need to smooth out the ducts on the front aero shield, as well as build snap-in pieces to cover the holes when they are not being used on the track as I don't want reduced efficiency on the street.
