Brake disc specs?
Discussion in 'Roadster: Technical' started by Moge, Sep 26, 2018.
  1. Moge
    Moge Member
    Oslo
    Hi,
    I'm in contact with www.eliseparts.com trying to source new brake discs. They are more then willing to help and are also looking to expand their site to show Roadster compatible parts and accessories.
    They've asked me to give them diameter, thickness and ideally offset from hub bearing face (or centreline of the disc rotor) for my 2.5/2011. Does any of you have that info?
  2. Moge
    Moge Member
    Oslo
    I was told that calipers, pads and brake discs from Lotus Elise S2 all fit the 2.5 Roadster, is this correct?
  3. ML Auto
    ML Auto Member
    SW Florida
    EBC USR1070 from the Saab 99-02 9-3 Turbo Viggen are the best replacement ones. They are 308mm in diameter so they require a 3/16 spacer under the caliper for the front (slight braking improvement), and are a bolt-on for the rear. They are much thicker and last forever.
    The hub specs are also the same as the Vauxhall vx220, so all the rotors Elise parts sells for that model fit.
    Stock sizes are 300mm front 310mm rear 26mm thick
    Info here:
    Roadster brake upgrade
    • Informative x 4
  4. da2ny
    da2ny 2010 Roadster Sport Twilight Blue #913
    Beverly Hills, CA
    I just replaced the seals for the sliding pins on rear Brembo calipers with replacements I got from Lotus Parts. Work like a charm. Also, installed EBC Yellow pads - Front and Rear which are spec'd for both Lotus Elise and Tesla Roadster. I used the yellows because they have excellent stopping power when cold. My brakes are almost always cold.
    • Informative x 2
  5. jnordeng
    jnordeng Member
    Norway
  6. Moge
    Moge Member
    Oslo
    I got this email from EliseParts after having shared the Roadster Brake Upgrad link.
    This is the reply:
    We can easily make brakes for the Tesla, lighter and better too as we make them for the full Lotus range now.
    All I need are Rotor O/D, rotor thickness, wheel PCD and disc offset and I can quote you price and lead time
    Anyone got this?
  7. gregd
    gregd Active Member
    CM98
  8. ML Auto
    ML Auto Member
    SW Florida
    Just tell them to use the rotor hats from the VX220, and use the disc specs previously mentioned.
  9. ML Auto
    ML Auto Member
    SW Florida
    Except the EBC rotors are 1/4 the price, slightly improve braking with bigger rotors in front, and stock off the shelf items available almost anywhere. The improvement comes from the slots in the rotors (wet performance) and the upgraded pads, the few pounds less weight doesn't give any measurable improvement.
  10. ICON
    ICON Member
    Hong Kong
    I need to get this !
  11. smac
    smac Active Member
    Nottinghamshire
    Also look for any parts related to the EU only Lotus Europa S.
    MTEC Do some "C-Hook" rotors. In theory these should be even better in the Roadster application than slotted rotors (being even more aggressive on the pad surface, which helps with wet performance).
    Brake Discs and Pads for Europa S 2.0 Turbo 07/06-
  12. gregd
    gregd Active Member
    CM98
    Do the EBCs rust? The huge improvement with the custom slotted rotors, at least for me, has been their lack of rust buildup. The slots help during the longer wet braking sessions; the lack of rust keeps my heart going during the first few seconds when dry after being wet.
  13. ICON
    ICON Member
    Hong Kong
    Thanks are these a straight swap - any modifications needed?
  14. Moge
    Moge Member
    Oslo
    And does that also go for the rear? I need a complete new set!
  15. ML Auto
    ML Auto Member
    SW Florida
    The link shows 4 lug and 288mm- so no. Maybe the Europa had 5 lugs for some model?
  16. ML Auto
    ML Auto Member
    SW Florida
    The exposed wear surface will get minor surface rust if they get wet, but that goes away with one brake application. The slots are what keep the rust from contaminating the pads, which happens with the stock rotors. The rest of the rotor remains coated with their black "Geomet" rustproof coating.
  17. ICON
    ICON Member
    Hong Kong
    Sorry I'm confused....so no they are not a straight swap or
    no no modifications are needed?
  18. X.l.r.8
    X.l.r.8 Supporting Member
    Toronto/Miami
    #18 X.l.r.8, Oct 2, 2018
  19. ML Auto
    ML Auto Member
    SW Florida
    The link posted shows 4 lug rotors, so those shown will not work (the size is also too small). Someone over in Europe had previously mentioned the Europa rotors would fit, but unless they had optional 5 lug rotors and were bigger in diameter, they will not.
    The V6 Exige rotors are 332mm x 32mm, so they will not work either.
  20. ICON
    ICON Member
    Hong Kong
    Thanks .... so what are our options?
