CorneliusRox
Out of curiosity, does anyone know if both rear wheels have the e-brake style caliper or just one side? I would guess both in the event that you break a half shaft, you'd lose Park functionality, but who knows.
Has to be both because when I put my wheels back on I can torque the rears without pulling my hair out. Wish I could simultaneously Hold the fronts.Out of curiosity, does anyone know if both rear wheels have the e-brake style caliper or just one side? I would guess both in the event that you break a half shaft, you'd lose Park functionality, but who knows.
You know, that is such a good point. ha haHas to be both because when I put my wheels back on I can torque the rears without pulling my hair out. Wish I could simultaneously Hold the fronts.
I'm glad no one is injured.Thank you everyone for their concerns.
I messaged the serviced department to see what's going on with my car and they are running diagnosis on it, I will update here when I get the report.
Here's the rough timeline of what happened.
07/16/2021 06:30 pm - Brake failure, was able to drive it home with regenerative brake
07/17/2021 09 am - called Tesla to report the problem, they asked me to turn off the car completely wait 2 minutes and turn it back on, brake still didn't work while running some tests and pressing on the brake pedal few times, "brake fluid low" notification popped up on the screen
07/17/2021 11 am - my car was towed, I could see some spills on the driveway, I always park at the same spot, never saw that before
I do have sentry cam footages and pictures & videos of brake not working but like someone said I do not feel comfortable uploading it here, I'll ask Tesla if they want to see it. Also I will file a complaint on NHTSA like someone mentioned, thank you.
In my experience testing from 5 mph it was not slow or little braking, it was violent. It's the same brake used for hill hold.Here's a video of how to actuate the e-brake while driving for those wondering:
You can see from just a random picture on Ebay of a Model 3 rear caliper there is a black part that is the servo motor that that parking brake actuates. This motor is electrically driven so it'll still work even if you lost all your brake fluid. Obviously due to it being only on the rear brakes and due to how the motor works, it's very slow, so the braking force is very little compared to normal brakes, but it's still better than nothing.
I guess it depends on if talking about the Model S (which uses a screw drive which is likely even slower) or 3 (which uses a servo). However, I get the impression it's still slower than the hydraulics. It may be more harsh since it bypasses all the other brake systems (like ABS), but the braking force is definitely much less than regular brakes. You can see that from the video when the car is going at higher speeds.In my experience testing from 5 mph it was not slow or little braking, it was violent. It's the same brake used for hill hold.
Make sure they answer your question in detail.
Huh... the classic, 'don't worry bro I got you covered'
You can't push for free stuff unless you know who is to blame. I still haven't heard anything that leads away from the attempted murder theory.
Wow this gets worse and worse. OP, I'd definitely push for a free 2 year ESA. That can help reassure your spouse that the car will be maintained safely.
No such thing as an ESA for a Model 3.
Wow, Tesla doesn't offer an extended service agreement? So it's just 4 years 50k? That's interesting.
