9erDog
Quick question, can you save selections like Creep on/off and others on Driver Profiles in the current software? I am on 2018.21.9 right now.
YesQuick question, can you save selections like Creep on/off and others on Driver Profiles in the current software? I am on 2018.21.9 right now.
Whenever you come to a complete stop if you depress the brake firmly it engages the brakes and holds them until you step on the accelerator.
Brake hold is only active when car is stopped and brake pedal is pressed firmly. It turns off when accelerator is pressed to move off.I also understand with this "hold" setting enabled, you don't have to continuously hold your brake? Meaning you can press on your brake until some notification comes on in which you can release the break pedal, your car will continue to break for you? I don't want to rear end anyone.
This is not a new thing. My 2012 Mini has it.
The brake Hold function works fine on steep San Francisco hills. Very useful.I know my Volt's hill hold feature changed driving in San Francisco for me! (Except the nasty financial district LOL!) If it can't already I sure hope they adjust the 3s to be similar because it is wonderful!
Yes, we really like it too. The only thing I wish is that it would stop the car from rolling backwards when starting on a hill. If you press on the accelerator, the brakes release immediately so the car can roll backwards a bit till the motor catches it.
To be fair, by doing that you are actively engaging the car in gear (you are no longer neutral, the RPMs will rise). Creep doesn't require the driver to do anything.But- manuals kinda do have creep.
If you let off the clutch partially in most manuals, without giving it gas, the car will creep forward.
Two things:Until now, I have always driven manual transmissions. Subaru is one of the most popular cars in Colorado. "Hill Hold" has been on Subarus for several years and was always very helpful when trying to start UP a hill. I believe there were a few other car models that also had that feature for manual transmissions. Not sure if they had it on automatics. I am curious.
I don't consider my leg modulating the clutch to be the same as an automatic which creeps or rolls without driver intervention. An automatic can be on a flat surface, without the brake pressed and drive forward...a manual will sit still (unless on a slope).... I'm pretty sure creep requires the car to be in D or R (ie "in gear")....and that, just like a manual (or traditional automatic), it won't go anywhere on its own in neutral.
Remember the context was using creep to park as something a manual couldn't do... when it absolutely can do that just by letting the clutch out a bit while in gear.
In the context An automatic can be on a flat surface, without the brake pressed and drive forward...a manual will sit still (unless on a slope).
But, I think I get what you are trying to convey, you can "creep" by just modulating the clutch, in order to aide parking situations. I agree.
