That seems a little low. If you’re changing brake pads every 25k miles then you need to learn how to drive better.I think OP is surprised by how good it looks.
On a standard ICE at 25k Mi it should be nearing the time to change the pads.
My M5 is no lightweight and I’m going on 70k miles, I agree that heavy braking would wear them out quicker but that’s not the proper way to stop the vehiclewell, a lot depends on how "heavy" you are on the pedals, and on how heavy is the car's weight.
For sure 25k mi is on the short side of a brake pad life, but not unheard of.
I feel like autopilot relies on brakes more than my normal driving would. I did replace my front ones at about 70K miles - but I'm also the second owner.
although my pads benefit from the vehicle slowing down when I downshift. But still 25k is bad
I like the soundInteresting. I always just coasted to a stop on my manuals. Always thought downshifting through the gears caused needless wear on transmissions vs cheaper cost of pad replacement
How to Downshift a Manual Car Correctly
The Dodge Caravan I had the displeasure of owning for 4 years went through front pads every 30,000 km (19,000 miles). Undersized rotors, an aggressive idle speed which caused it to accelerate down hills, and I lived where there are plenty of hills...
@David99 did his brakes for the first time earlier this year I believe... what was the mileage again David?
