Brake pedal play / rattle when lifting off pedal...
Discussion in 'Model S: Driving Dynamics' started by patn, Mar 10, 2014.
  1. steilkurve
    steilkurve Member
    Montreal, Canada
    That I have noticed. Doesn't bother me that much. What I'm talking about is a squeaky sound as I apply or release the breaks. Like two pieces of rubber rubbing against one another. That's what I'm trying to diagnose if anyone else has the same.
  2. PatD
    PatD Member
    Broomall, PA
    Anyone ever hear more information from Tesla on this? I'm at my service center today and the service writer said he never heard of this and doesn't know of any known issues or fixes.
  3. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    When I took my car in for this issue (among others), my service advisor said that there was some play and that engineering was working on a new part to minimize the rattling sound. He also said that my car wasn't any worse off than a handful of other cars they tested. (Looking back on that, his second comment is completely irrelevent and I should have said so at the time.) I plan to bring this up again next time I take the car in, whenever that happens to be.
  4. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Reviving an old issue thread.
    Just picked up my 2013 CPO, and, man the brake pedal is loud. It rattles at the top like it's loose or something, and it creaks when I press it. I have an SC appointment early next year, and I will mention it then, I just wondered if there is a fix.
  5. mknox
    mknox Well-Known Member
    Toronto, ON
    My Feb 2103 build car does this as well. A kind of creak/groan sometimes when you press the brake and a bit of a "rattle"-like issue as well. Never bothered me enough to do anything about, however.
  6. cab
    cab Active Member
    Grapevine, TX
    Have the same issue, but it has been lower on my list of items to look at. Even though I am CPO - 2013 - and have plenty of warranty, I often find I am better at fixing this kind of stuff than shops are. Part of that is simply because I am willing to spend inordinate amounts of time on it...and I am the one with the greatest vested interest in resolving it.
  7. Drucifer
    Drucifer Active Member
    Charlotte, NC
    The service center fixed my rattle. I never had it happen again after they fixed it.
  8. cab
    cab Active Member
    Grapevine, TX
    #68 cab, Dec 19, 2016
    Do you happen to know what they did? I reached up underneath there (didn't look as I only hasd a second and it was 20 degreess out) and it feels like there is simply a metal brake pedal pin and cotter pin similar to this generic pic in there:
    It seemed to have a ton of slop as I wiggled the pedal. Normally, I would expect to see a plastic bushing in there like these generic examples:
    The bushing go in like this Honda example (2 parts: 47101B):
    Sometimes the play is side to side and a thin wave washer is needed (not sure that is the case here).
  9. Drucifer
    Charlotte, NC
    That totally makes sense. I wasn't curious enough to check it out. Just glad they fixed it.
  10. JST
    JST Active Member
    When I took mine in, the service center said that there was a service bulletin to replace the brake fluid and flush the system. That helped a little, but not a lot. I ended up trading it before I could do anything further about it. My "new" CPO 2014 does not have this issue.
  11. ToddRLockwood
    ToddRLockwood Active Member
    Burlington, Vermont
    My (former) Feb 2013 build P85 had a related issue. When slipping my foot off the pedal, allowing it to spring back to its rest position, it made the sound of a plastic hammer striking and bouncing on an anvil. On the 2016 cars, Tesla has eliminated this problem (with a proper rubber bumper) as well as a myriad of other peccadilloes found on the early production vehicles. They're learning.
  12. Az_Rael
    Palmdale, CA
    Dropped mine off at the SC today for this issue. Tech rode with me to hear the creak noise and lift off rattle. He wasn't sure if that was normal behavior for the classic cars tho (which made me roll my eyes a bit - I have never owned a car whose brake pedal makes that much noise - I have a hard time believing its normal).
    I ended up in a slightly-older-than-mine classic S85 loaner, which had a much better brake pedal feel compared to mine. It didn't creak, and it felt "tighter" if that makes sense. Some amount of noise on lift-off, but not as bad as my P85. So I let the service advisor know it WAS actually different from my car.
    Hopefully they will be able to find something to fix.
  13. Az_Rael
    Palmdale, CA
    Got mine back from the SC today. They ended up applying some sort of silicon lubrication to the brake pedal mechanism to eliminate my creak noise. Lift off rattle is still there, which was less bothersome than the creak noise. Hopefully the fix will last.
  14. Qbenjamin
    Qbenjamin Frugal But Classy!
    Braavos
    I have the same issue on my 14 MS. I didn't really notice it until my wife pointed it out a couple of days ago. It almost sounds as if something is loose on the brake housing. We don't have this issue on either of our non-luxury vehicles, which makes it even worse for the MS.
  15. cab
    cab Active Member
    Grapevine, TX
    I did briefly reach up under there and wiggle the little cotter pin on min. I noticed when I slid it left or right it was much tighter so to it could just be wear on the center of the pin. Having said that, I couldn't tell if that was really the issue or the bumper that Todd mentions above. It is too tight to see under there w/o removing some panels and it hasn't gotten to the top of my annoyance list as of yet to botehr investigating further...
  16. Looking-for-S
    Looking-for-S Member
    Maryland
    I also have this rattle on my 2015 MS. Drives me crazy. Sounds like my college beater.
    Will ask service to look at it.
    Currently waiting 6 weeks for service appointments here, so won't be fast.
  17. Live_Wire
    Live_Wire Member
    Madison, CT
    Have the same clatter noise when lifting off the brake pedal. Everybody has been saying Tesla is working on a fix for this but has that fix ever made an appearance? Seems like it's not very hard to figure out.
  18. Medpilot
    Medpilot Member
    Phoenix
    My 2014 P85D does the same thing. A rather loud "clunk" sound when lifting my foot off the brake pedal. l'll write my local SC adviser an email and see what they have to say.
  19. jzafra88
    jzafra88 Member
    Bay Area
    Any updates on this? I've had my CPO 2015 for a month now and this has drove me crazy since day 1
  20. Dpc131
    Dpc131 Member
    Leonardtown, MD
    Just had the pin replaced in mine also a 2015 (which I hoped they would cover under goodwill since I have 51k miles and just got the car used a month ago)
    It definitely makes a difference. when I asked at the SC the technician nodded that there was a new part and seemed to acknowledge what I said.
    That being said, it still clunks if I leave go, but much closer to the loaner 75D I had. Not as loud and not as much reverberation. I would say it’s worth the upgrade.
    Cost me $13 for the part and $64 for labor. Errr.
