Brake squealing?
Discussion in 'Model X' started by nsoriano85, Aug 16, 2017.
Tags:
  1. nsoriano85
    nsoriano85 Member
    West Des Moines, IA
    Just picked up new mx100 and the car drives like a champ however it rained for the first time since getting it and the next time I started driving it the brakes were squealing for the first 3 min of the drive but only when I applied them not when regen braking was active. Is this a problem I should get checked out asap or is this something that just happens due to the regen braking?
  2. Peteybabes
    Peteybabes redneck drivin' a tesla...
    'murica
    i believe it's something that happens with just about every Tesla because the main brakes are largely unused compared to an ICE car...
  3. Shawn Snider
    Shawn Snider Member
    BC, Canada
    ^ This, fresh pads squeal a bit as they contact the rotor's the first few times, once the pad wears a little bit it should go away.
  4. deonb
    deonb Supporting Member
    Redmond, WA
    All high performance breaks will squeal for the first few thousand miles. Mine did it for 4 months or so.
    It definitely will go away. Until then, only drive in up-scale neighborhoods - people over there will know you're driving a new car, as opposed to thinking it's broken ;)
  5. Freedom101
    Freedom101 Member
    Vancouver BC
    I've noticed it as well and picked mine up 3 weeks ago. As mentioned above it's normal... If it continues beyond the first few thousand miles/km then I'll bring it in.
  6. outie
    outie Active Member
    SoCal
    Mine still squeaks next day after a car wash on my driveway. It goes away after applying the brake fee times. Car has more than 8k miles. As long as your brake works it's not a concern. Brake noise is pretty normal.
  7. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    My squealing went away around 5,000 mi. Never had this on my Model s
  8. BigMskiman
    BigMskiman Member
    Pleasanton
    Both my MX exhibit(ed) the squeal, only while backing down outta the garage to street, and only after a rain.
    Quiet driving thereafter in the rain or dry. Both with <20k miles.
  9. zackmilo
    zackmilo Matching X+3
    Los Angeles, CA
    I took mine in and they replaced rotors FOR FREE. Haven't squeaked since.
  10. Peteybabes
    'murica
    wait you got the new beast!? (can't wait so see your updates soon :D)
  11. zackmilo
    Los Angeles, CA
    My old beast!!! Rip. Lol
  12. ckwong
    ckwong Member
    Northern NJ
    Since this topic is regarding brake squealing, what about when you are parking and have to turn the wheel a few times and go from D to R a few times as well? Mine squeal a lot and I've asked a SC tech and he said that is normal. But it really sounds like something is wrong...I have 3500 miles. Anybody have this problem? Thanks
  13. BigMskiman
    BigMskiman Member
    Pleasanton
    No, don't have that happening at all.
  14. wallstguy
    wallstguy Member
    Toronto, Canada
    Not sure about a few thousand....but Tesla mentioned some cars have a bad batch of rotors, and they need to be changed. Mine was one of them, it would "screech" when braking, and they replaced rotors and made it go away :)
  15. Maximus-MX
    Maximus-MX Member
    Greeley, CO
    Mine was squeaking for about a month (~1000 miles). Then it went away. They told me to give it some time when I called them.
  16. Peteybabes
    'murica
    raining this morning, and quite pronounced squeaking at low speed...don't think it require brake replacement though...
  17. travwill
    travwill Active Member
    Chicago, IL
    I notice this after car sits, after a car wash, rain/snow at times, squealing or scratching. It seems like it is due to little use of brakes and regenerative instead. I even can hear some grinding at time at slow speeds in quiet areas (maybe some build-up on brakes?).
    If i get on the freeway some finally, and do some hard braking for a while it all seems to go away for a bit. Just have to use the brakes actually a little and well.
  18. digicool
    digicool Member
    Seattle
    Happens on mine routinely after some rain and sometimes even with no rain. I checked with service, they first burnished it, then replaced the rotors to the new version - still makes noise.
    Service said thats something I may have to live with - and that its not un-common in heavy cars.
    For now I let it settle but it does annoy me everytime I hear it.
  19. nsoriano85
    nsoriano85 Member
    West Des Moines, IA
    I talked to a SC and they said it's totally normal and recommended I hammer the brakes a couple times to shave the thin layer of rust that forms on them overnight it'll make the squealing go away. I haven't had a problem since my original post here with squealing despite it raining but I don't think I'll be hammering the brakes anytime soon even if they do start squealing again.
