Brakes on Autopilot Cars
Discussion in 'Model S: Driving Dynamics' started by 1NJ85D, Mar 27, 2015.
  1. 1NJ85D
    1NJ85D Member
    Scotch Plains, NJ
    Are the brakes on recent cars hydraulic or electric? Thanks
  2. Saghost
    Saghost Well-Known Member
    Delaware
    Yes. :)
    The braking system is still hydraulic, with the typical dual master cylinder driving conventional disc brakes.
    However, the booster is now electric. Tesla appears to be using a version of Bosch's iBooster system - there is an electric motor geared directly to the master cylinder piston, which can apply boost (or apply the brakes without the operator) at any time, using electric power to pressurize the hydraulic fluid in the brake system.
    Walter
  3. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    The new system has several advantages over the old, including:
    1. Improved pedal feel. More immediate grip. Not mushy anymore. Feels more BMW, less Lexus.
    2. No more vacuum pump, since the brake boost assist is now electromechanical. This means no more vacuum pump sound, which I found loud and annoying.
  4. 1NJ85D
    1NJ85D Member
    Scotch Plains, NJ
    Thank you both. That was precisely the type of info I was looking for!
