It replied to the wrong message. I saw your response to the post.Umm, yes, I know, hence why I asked the question without outright saying “Did you read the responses above?”
There’s certainly no way to disable it as people generally expect their cars to stay where they were left when parked.and I know of no way to disable it.
I am learning. I thought my Tesla had a "stop" , a parking prawl, on a drive gear when you placed it into park to hold it like a normal car. I hope the parking brake is better than an ICE car, because those were never sufficient to hold a car on a hill. Park always kept it parked.There’s certainly no way to disable it as people generally expect their cars to stay where they were left when parked.
We still have this problem, car is in the shop now its crazy 3 years now!The past week I've twice got into my car in my garage in the morning (after it was sitting overnight), powered on the car and selected Reverse yet the car won't move when I apply the usual light pressure to the accelerator. The first time I thought I'd done something wrong and switched back to Park, then back to Reverse. Same result so I just pushed a little harder on the accelerator and it felt like the car strained against the brakes then they released with a "clunk" and abrupt movement. Same thing today. Anybody experienced this?
You will continue to have this problem, as it's not actually a problem.We still have this problem, car is in the shop now its crazy 3 years now!
We have the same problem and the local dealer refuses to look at it or even fix it for 3 years now and the problem is only getting worse. Now they are saying they know the problem and its the disc brakes fusing to the rotors. Now they are saying its common even the new cars do it. This means they have been lying to us for 3 years, we are at a loss of what to do they are threatening us with Tesla`s legal department if we continue to try to get the car fixed. Crazy crazy experience They have a design problem resulting in a defect and safety flaw and expect us to ignore it.The past week I've twice got into my car in my garage in the morning (after it was sitting overnight), powered on the car and selected Reverse yet the car won't move when I apply the usual light pressure to the accelerator. The first time I thought I'd done something wrong and switched back to Park, then back to Reverse. Same result so I just pushed a little harder on the accelerator and it felt like the car strained against the brakes then they released with a "clunk" and abrupt movement. Same thing today. Anybody experienced this?
My BMWs and Mercedes had this same issue when you park the car with the emergency brake on when the rotors are wet. It is not a design defect. It is normal for the rotors to corrode as they dry and fuse to the brake pads. If Tesla had a true "park" with a stop gear on it, you may not be forced to use the Tesla emergency brake, which is applied automatically for you even if you park in a flat garage or surface. Without the emergency brake applied, you would not experience this issue.We have the same problem and the local dealer refuses to look at it or even fix it for 3 years now and the problem is only getting worse. Now they are saying they know the problem and its the disc brakes fusing to the rotors. Now they are saying its common even the new cars do it. This means they have been lying to us for 3 years, we are at a loss of what to do they are threatening us with Tesla`s legal department if we continue to try to get the car fixed. Crazy crazy experience They have a design problem resulting in a defect and safety flaw and expect us to ignore it.
You could always stop wasting their time and your time trying to fix a problem that is not actually a problem.we are at a loss of what to do they are threatening us with Tesla`s legal department if we continue to try to get the car fixed.
LOL....You must work for Tesla. lolololol very funny!You will continue to have this problem, as it's not actually a problem.
Nope, I've just driven cars for a long time and understand how brakes work. It's not a particularly high bar.LOL....You must work for Tesla. lolololol very funny!
You could also stop responding to the same post in the same thread with the same info repeatedly in hopes of a different result.
To anybody that thinks the brake pads sticking to the rotors after getting wet and being parked is a problem, then just replace your brakes pads with non-metallic ones (ceramic brake pads). The OEM pads are semi-metallic, which means that they actually have metal particles in the friction material. Those particles rust to the steel rotors and stick. I went through a few months 2 years ago where my brakes would stick like this, until I started using my brake pedal every time it rained or I washed my car. That helped dry them out versus just relying on regen.
This is a New Car under warranty, Do you work for Tesla your on like 15000 post?This is an old problem with brake pads and getting wet. My 1992 Buick did the same thing in the winter if I put the parking brake on in the garage. New cars have electronic parking brakes that always engage when you park. For electric cars it's a necessity because you don't have the transmission (in automatic transmission ICE) to hold the car in place when parked.
In wet weather the brakes get wet along with the wheels. When the parking brake is engaged, the pads develop rust and stick. It doesn't matter if they are disc or drum, if the brake pads have any iron in them, they will rust to the wheel.
It's Physics. Someone mentioned getting ceramic brake pads. It's about the only solution, though I don't think ceramic has the stopping power of pads with steel embedded.
Yes. We all work for Tesla. We’re actually all TeslaBot AI accounts programmed to tell you the same thing to throw you off the scent of the serious problem and safety defect you’ve discovered.This is a New Car under warranty, Do you work for Tesla your on like 15000 post?
LOL You are vary funny!Yes. We all work for Tesla. We’re actually all TeslaBot AI accounts programmed to tell you the same thing to throw you off the scent of the serious problem and safety defect you’ve discovered.
Warranties are for things that are broken, not imaginary problems.
Honest question: how often does this really happen for you? As others have repeatedly stated, this is not a defect or real problem. Iron rusts, almost “instantly” in the case of rotors. Usually the worst after a car wash. Normal rain driving and then next day start will also produce the clunk as you overcome the sticking pad-to-rotor condition.LOL You are vary funny!
