I am not an electrician, nor do I play one on TV, but I believe that if your house is wired with a common neutrals, i.e. two separate circuits sharing only a single neutral wire back to the panel, I believe that tied breakers are now recommended(?), or required by code.
@wwhitney?
Again, not an expert, but I believe that the thinking is that by tying the breakers together, you ensure that the return neutral is unpowered when the breaker is off. With unpaired breakers, the "other" breaker could be energizing the common neutral, making the common neutral potentially unsafe to work on / be around.
All the best,
BG
I am no where near close to being an Electrician, nor did I stay in a holiday express anytime recently, however, for the OP, my install had something similar. I have a "critical loads panel" that was installed, but every load in my home except for 1 is in my critical loads panel. The only load left in my original panel (other than the main breaker) is my EV charging circuit.
Anyway, my tesla installers did something similar, except they are bonded together not with the plastic cap, but with the metal pin between them. When I asked "how come I used to be able to turn off the circuit for my dining room individually, but now its paired with another circuit breaker", the tesla electrician basically explained something close to what
@BGbreeder did above.
Boiled down to "new code" based on common neutrals I think. My lead tesla installer was fairly high up on the electrician chain for tesla, too. He told me he did the first residential powerwall install for tesla, and was a teaching electrician within the company, and one of their master electricians.
He was really chill, and super cool to chat with while they were doing my install. He was traveling around teaching powerwall installs to other crews, but lives in a city close to me, so when he wasnt traveling he did "local" installs. I got lucky to get him imo.
TL ; DR -- OP, think its normal depending on electical system in your home, and local codes.
