Brembo Caliper Covers
Discussion in 'Roadster 2008-2012' started by bart513, Sep 2, 2014.
Tags:
  1. FreeOfPge
    FreeOfPge Member
  2. Chillout
    Chillout Member
    the Netherlands
    Don't buy them... it would be easier to just paint it with Hammerite. I did this before on several cars and isn't that hard once you have all the masking tape in place.
    Why I suggest not to buy these? You have to use strong glue to apply the cheap plastic part, on a part that can get pretty hot, and is close to some very vast spinning parts. I guess no one would like it to come off and hit your wheel/brake lines/body work, have stuff melting down on your calipers, or have the service point unable to reach the needed parts of the brakes because you glued a cheap cover onto it..
    So.. just get some hammerite and have fun :) I still have a tutorial to do this, somewhere on the net. I can post it if you like.
  3. bart513
    bart513 Active Member
    East Hampton
    #4 bart513, Sep 2, 2014
    Many good reasons not to use this particular cover. I'm not that handy but maybe the tutorial would make it easier:smile:
    I remember reading that there might be issues of brake dust making cleaning the caliper a problem?
    It does say "Front & Rear: Thick ABS Plastics Withstand Heat, Light Weight , no melt guaranteed!!!"
  4. Chillout
    Chillout Member
    the Netherlands
  5. bart513
    East Hampton
    Thank you Chillout!
  6. TOBASH
    TOBASH Supporting Member
    Rockaway Beach, New York
    Anything that retains heat in the braking system is bad. It cooks the fluid and prematurely wears the caliper pistons.
    I will at some point upgrade the brakes when my warranty expires as I am not fond of the weak braking.
    Please take the following in the good spirit it is meant...
    As far as "saving money" by covering the caliper with a plastic Brembo cap... You own a kick ass limited production $100k roadster that is as original and unique as they come, and needs no cosmetic polishing. Are you really considering a 15 dollar fake brake upgrade? (And what will that say to the future used car buyer and the future value?)
    Consider paint or a caliper upgrade.
    Just my humble $0.02
    Best,
    T
  7. hcsharp
    hcsharp Active Member
    Vermont
    That's true with an ICE car and a Roadster on a track. The Roadster has a little problem with not getting enough heat in the brake fluid, which it needs to evaporate the moisture that accumulates in it. That's why Tesla started recommending that you flush your brake fluid at least every 2 years. Several of us on this forum have noticed the fluid thicken and turn to sludge if you wait much longer than 2 years if you live in a humid climate.
    Otherwise I agree with everything you said about the plastic caliper covers.
    Well said.
  8. wiztecy
    wiztecy Active Member
    #9 wiztecy, Sep 4, 2014
    Also the covers in the link were fakes (non-Brembo from a China Seller). I'm sure Brembo wouldn't sell such a thing that'd negativly effect the braking components. Here's a couple of videos where you'll get a nice laugh...
    The first part is all you have to watch, the labeling... Its what you would have expected from fake stuff coming from China:
    This one talks about brake fade that can occur from the cover and stresses not to install them:
  9. TOBASH
    Thanks for your kind words HCSHARP.
    Just a note as to brake fluid from what I learned as a former mechanic and as a former street modifier/racer, (and as an additional explanation for BART513):
    AFAIK...regarding brake fluid changing color and requiring change every 2 years...
    DOT 3 and DOT 4 brake fluids are hydrophilic. They actively absorb water in an effort to shield brake parts from oxidation induced wear and blockage. They also degrade with heat over time. As such, all my vehicles get new DOT 4 every 2 years. Humid areas will allow the fluid to see more water so it will scavenge more water, and thereby degrade more quickly. This is not just a TESLA phenomenon. Just go to any one of your other cars and compare the fluid in the overflow with fluid in a new container. You will immediately see the color difference.
    A heat shield will speed up the process of fluid degradation, as well as create "fade" as per the video that was provided by Wiztecy. I believe the heat range of brake fluid is just shy of 500 degrees F. Retaining heat expands and even vaporizes the fluid. The fluid no longer transmits forces effectively to the piston(s) in the caliper(s). Clamping forces are delayed and reduced and can result in longer stop distances. This is why many racers have air ducts pointed at the braking systems. It is not just to keep rotors and pads cool. It is also to keep caliper temps under control.
    DOT 5 is hydrophobic and should never be used in cars not meant for DOT 5 use, as DOT 5 repels water and will not protect parts. Worse, water will collect in dependent areas and corrode those areas.
    For those of us under warranty, I suggest letting Tesla do the changes each and every time, for documentation purposes.
    Best,
    T
  10. bart513
    East Hampton
    Thanks again for all of the information on why NOT to buy those caliper covers!!!:eek:
  11. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    After two years I had to insist that Tesla change my brake fluid. Their response was, "it's not on the maintenance schedule". I pointed out that it now looked like coca-cola! They charged me extra for the flush but they did it.
    I now have the necessary gadget to conveniently flush it myself...
  12. artsci
    artsci Sponsor
    Timonium, Maryland
    Plus the all the calipers are Brembos to begin with. So no fake covers needed.
  13. m0rph
    m0rph Member
    Belgium
    Well, they are AP Racings.. The OEM pads are Brembo :wink:
  14. wiztecy
  15. m0rph
    m0rph Member
    Belgium
    Didn't know that! Again I learned something today on TMC :biggrin:
