Broken Falcon Door Button
Discussion in 'Model X' started by bak_phy, Jun 28, 2018.
  1. bak_phy
    bak_phy Member
    New Jersey
    The button (or mini handle thingy) used to open the left falcon door popped out a bit and now the door can't be opened from the inside although it can still be closed. Has anybody else had this? Given the many times the handle is pulled on by kids I can imagine that they can break pretty quickly. The car is two years old.
  2. r0xx0r
    r0xx0r Member
    You can bring it to the Tesla SC. These buttons have the newer version, which is click button - not pull anymore.
    Check here:
    New FWD switch design
  3. bak_phy
    bak_phy Member
    New Jersey
    Thanks. I figured it couldn't just be me having this issue.
  4. r0xx0r
    r0xx0r Member
    Yup! Mine was broken because my mom lifted the button really hard. When you bring your car to the SC, tell them that the other button sometimes didn't work too. That is why you had to pull/push it so hard to get it worked. Make sure they will replace both :p
