broken soft top tension wire
Discussion in 'Roadster' started by tonybelding, Feb 26, 2019.
  1. tonybelding
    tonybelding Active Member
    Hamilton, Texas
    So, through some ignorant manipulation I managed to break the tension wire (or more of a thin cable, really) that seals the front edge of the soft top. It snapped, it's got to be replaced. The soft top is identical to a Lotus one, right? What's the best way for me to source a replacement for that wire?
  2. Panicopticon
    Panicopticon Member
    Syracuse, NY, USA
    #2 Panicopticon, Feb 26, 2019
    I replaced mine with these, unlike the originals you can readily replace the cable. They also have the advantage of being a bit more robustly designed. Should that auction disappear, the magic search term is "VX220 Lotus ELISE EXIGE Soft Top Roof Cable adjuster tensioner Opel Speedster". I paid about $42 GPB each for my pair from the seller above.
    I have the persons email address, if you want to contact him directly, drop me a line and I'll pass it along.
  3. djp
    djp Roadster 2.0 VIN939
    Toronto, Canada
    I replaced mine with a length of non-stretch Spectra line. Cheaper than cable and available at any marine store.
  4. ion_1
    ion_1 Member
    NJ
    I replaced mine with the stock Lotus soft top tension wire. Worked perfectly, easy swap. But I do like the ones Panicopticon suggested. May try those in the future.
  5. tonybelding
    Hamilton, Texas
    I'm going for that. Thanks for pointing me towards it!
    TMC forum proves its worth yet again.
  6. Panicopticon
    Panicopticon Member
    Syracuse, NY, USA
    My one complaint, and its a minor one, is that the thickness of the ends can make them a little more difficult to fit properly in the A and B hoop slots. Related, you might consider shrink tubing or tape wrapping the ends to keep them to keep them from rubbing against the hoop slots. I haven't noticed this to be any more of an issue than the original cables, but depending on your desired tension level, I could see how it might happen.
  7. Logticom
    Logticom Roadster Sport EU #243
    Zwolle The Netherlands
    @Panicopticon Thanks for the tip! Sounds and looks good. One of my tension wires is almost broken and I just ordered a new set through your link on eBay.
  8. jfischer
    jfischer Member
    Houston
    #8 jfischer, Feb 28, 2019
    I ordered one directly from Tesla and got it without any difficulties. I also got the TESLA car cover as well from parts.
  9. ICON
    ICON Member
    Hong Kong
    Did you send up selling your car ?
  10. Timothy
    Timothy Driving on Sunshine
    I just ordered--now $59.2 GBP so $77.22 USD with shipping. In the past eight yearsI have had the Tesla cables break 4 times--so I hope these last better!
  11. Timothy
    Oops. $49.95 GBP
