dhrivnak
And then charge immediately while still warm.Can you drive the car 4-5 miles? That has always cleared up the fault with my car.
PS have I said how I hate the very short edit window.
It won't charge if any cells are at 2.5v. Even the 3.1v cells are too low to charge using the Roadster's BMS. You'll have to charge the battery manually and very slowly. Make sure the cells are at least 6C.
Good that you have pulled the plug to get things warm and reduce discharge on the battery - but remember you need the plug back in to recharge. There is a micro switch on the lever when you close it to secure the plug in place...otherwise you will get the BSM Contacter failure. Hope this helps.
The voltage limit is approximately 3.5v. I don't know the exact number but it's within .1v of 3.5.I see, what is the voltage limit?
I don't understand the sentence about 6C.
I find it strange that it shows this BMS Contractor failure error message, it should display a "too low voltage to charge battery" message.
I tried charging after heating the car as described in my previous post, lowest brick was now at 2.7v and temperature 9 degrees C. I got the same error message.
In case I have to charge the battery manually in the future, is it explained somewhere?You'll have to charge the battery manually and very slowly.
I had exactly the same errors last Sunday, during sunny weather.
They where caused by overheating I think, because I was driving along the highway at high speeds ( 180km + ) , fooling arround with two Elises for about 20 minutes...
when the errors popped-up , I of course slowed down and let the car cool down , and the errors disappeared.
it was certainly not moisture related in my case but heat...
I also had the next 2 errors a coulple of days ago:
#283 BSM: Isolation fault
#286 BSM: Isolation fault while contactors closed
In my case I had the errors while driving fast in dry weather.
Aprox 170 km/h for about 15 min.
@BartJ : Did you have these errors just once while driving fast? Or did you get these errors more often while driving fast?
Gr,
Marcel
