Bubble on driver screen
Discussion in 'Model S: User Interface' started by ModelSFL, May 30, 2017.
  1. ModelSFL
    ModelSFL Member
    Central, FL
    I noticed people getting bubbles on the touch screen but I haven't seen anyone with this issue on the driver side screen. I noticed this few days ago and it seems every day the bubble moves around.
    Has anyone experienced this? if so what was the fix?
  2. Spidy
    Spidy Active Member
    EU
    #2 Spidy, May 30, 2017
  3. ModelSFL
    ModelSFL Member
    Central, FL
    @Spidy To clarify, this is behind the steering wheel not the touchscreen.
  4. Tam
    Tam Active Member
    Visalia, CA
    You are the first the I've heard!
    I wonder why it happens to Tesla while I haven't heard from others in computers, TVs, monitors, cell phones, tablets...
    I hope you are still under warranty.
  5. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
    Agreed, the first time I've heard it happening on the driver screen. :(
  6. ModelSFL
    ModelSFL Member
    Central, FL
    I still have about 2k miles left on the 50k warranty so that is the good news. The local shop asked I send them pictures as they haven't seen it prior so they need to see how they would fix it. I wonder if it is heat related as we just got into the hot season..looks like it is 108 degrees in the car right now.
  7. Tam
    Tam Active Member
    Visalia, CA
    Some house their cars in garage and still, it happens.
  8. SMAlset
    SMAlset Active Member
    SF Bay Area
    Can't say I've seen this issue with that screen either on any of the forums. That's a bit alarming to see bubbles in that screen too. I see you are in Florida. Curious what year your car is and if the car is parked outside during the day. In the meantime you should check out using the Cabin Overheat Protection to keep the car no hotter than 105F when you can. It's meant to keep kids and pets safe if left in the car, but we live inland and summer temps can get hot here too and I've been trying to remember to activate it every day when temps are up. You need to have sat in the drivers seat or driven that day (12 hours coverage, unless SOC is 20% or less). Look under climate control in your manual. BTW AC preconditioning, where you can set the temp from your app, only stays on for 30 min and then needs to be restarted each half hour.
    Keep us advised what service ends up doing. Thanks.
  9. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    That's a new feature of the 8.1 UI. You're supposed to chase that bubble around with your finger, and if you do it just right, it will unlock a special easter egg that will give us a usable infotainment system.
    • Funny x 2
  10. apacheguy
    apacheguy S Sig #255
    So Cal
    Oh, interesting. The IC panel is just an LCD so there is no glass to delaminate like on the CID.
  11. Buster1
    Buster1 Member
    Las Vegas
    Any chance there's a protective film on that screen, similar to iPhone screen protectors?
