BUG: After summon car does not open/unlock immediately
Discussion in 'Model S: User Interface' started by Korben, Jan 14, 2016.
  1. Korben
    Korben Member
    MSNOW, KORT677, and Korben all have seen this behavior. Not yet spent time to characterize. Anyone else seeing it?
  2. JenniferQ
    JenniferQ Supporting Member
    San Diego, CA
    #2 JenniferQ, Jan 14, 2016
    Yep. Haven't spent time either, but have noticed. Thought might be a security issue.
    Just happened again. Used Summon to get car out of a spot someone had parked too close to me in, and I didn't want to squeeze in. Cool to back car out RC, but uncool to not be able to then get in and drive away!
  3. mmccord
    mmccord Member
    Pine Bush, NY
  4. daled
    daled Member
    Chicago
    Yes, I've noticed this too. I'll try to tap the door handle, but it won't open. I end up having to use my key fob to open.
  5. Stoneymonster
    Stoneymonster Active Member
    Aptos, Ca
  6. liuping
    liuping Active Member
    San Diego
    I noticed that too. I've only tried it twice, but both times the car was locked when I approached.
    I think is might be because I stopped the summon via the fod, which is the same button used to lock the doors. They should check if it's used to stop summon and not lock the door in that case.
  7. kort677
    kort677 Banned
    florida.
    it happens to me regardless of me using the fob to stop the processes or not using it to stop the car
  8. caps04
    caps04 Member
    NJ USA
    Yep. This is the first time I've experienced handles not popping as I approach the car. And only after using Summon.
  9. Dark Shadow
    Dark Shadow New Member
    sarasota, florida
    Car should not unlock after summons because if it did and mirrors where not clear of obstructions it could interfere with extension of mirrors as car unlocks, probably makes sense to have it this way.
  10. jsimon77
    jsimon77 Member
    Los Angeles, Ca
    Same...I had to use the key fob to unlock the doors.
  11. Electricfan
    Electricfan Active Member
    Houston
    I have auto-present (or whatever its called - when I approach my car the handles do not come out, because I don't like them coming out every time I go into my garage) turned off on my car. I used Summon for the first time today after being blocked out of my drivers side door by a truck parking too close to me. When I touched the handle the handle presented normally.
  12. Entaum
    Entaum Member
    Miami, FL
    Same here... had to press the center button a few times to get the door open... problem was that my car ended blocking the garage and another car was waiting and looking at me like I was a crazy person... :)
  13. Rockster
    Rockster Active Member
    McKinney, TX
    I thought it was intentional, in that I didn't think it would be safe to assume that just because I repositioned the car I also wanted it to unlock itself. I'd prefer summoning and unlocking be separate actions, each of which must be gestured for.
  14. Korben
    Korben Member
    I am standing next to the car with fob in hand. I have autopresent handles enabled. A rational default would be to, at least, open at a touch. At best, once it stops present handles again.
  15. DieAbetic
    DieAbetic Member
    Los Angeles
    Same issue here, although not every time
  16. slevit1md
    slevit1md Member
    Oregon
    Yup, have to open with fob. It's annoying.
  17. tezzla
    tezzla Member
    SoCal
    I believe it's because the car doesn't know the situation, it doesn't "know" it's in a garage, it only knows forward or backwards. Although, like many others, I think it should unlock after summon, then autolock (in 20 seconds) as if just getting out.
  18. Korben
    Korben Member
    #18 Korben, Jan 15, 2016
    I think I have a better understanding of what is going on. Have not really experimented as I am pretty busy this week. If I am wrong I know many will be glad to point out what I missed. I am not proud.:smile:
    1. I am very impatient. The car, eventually, presents the handles or at least allows me to get in but I start clicking when it does not immediately open.
    2. If you press the center button on the fob it seems that this creates additional delay by locking the car which then requires another click to open
    A couple things I would look at.
    • When summon is stopped by FOB
      • Present handles immediately when parking brake is set "post" FOB click. I say immediately as it seems there is some delay in the logic here. Disregard the FOB click as a locking request until after the parking brake is set and the handles are extended.
    • When summon stops naturally
      • Check for presence of FOB AND immediately present handles when parking brake is set.
    In both of the above it would need to be gated by the setting of "auto present handles" which should give you the option to get in the car as if you had just walked up to it. Without auto present it seems like the rational default is to not unlock until the driver explicitly requests an unlock event (driver side or otherwise).
    This is still total guesswork. I have spent no time testing. Seems like an easy bug fix with timing of post summon setting the parking brake and auto present handles as key variables.
  19. Korben
    Korben Member
    #19 Korben, Mar 2, 2016
    Quick shout out to Tesla. After the latest firmware upgrade the doors now open automatically after it finishes it's sequence! Nicely done and much improved.
    When combined with the double tap of the stalk for parking the ease of use has gone up dramatically.
    Oh, the kind of fun downside to double tap. I keep forgetting to charge my car because the double tap to park is so easy and I just walk into the house.
  20. edwolb
    edwolb Member
    Oakville, Canada
    I'm in Canada and still seeing problems with summon. Most of the time it just doesn't work, and fails on the app. When it does fail a number of things seem to go wrong. Even though the handles auto present, I had the alarm go off when I opened the door. Today summon failed again and when I got in to drive it, the mirrors didn't auto-unfold. Full of bugs so far, and haven't been able to make any real use of it.
