Building/Fire code: can't install charger in garage? Really?
bcsteeve
647
651
Kelowna, BC Canada
I've got a used Model S on the way in a week, and I had an electrician come out to install a charger. I figure my situation is pretty typical. The electrical panel is in the house on the shared wall that separates the garage from the house, but one level down from the garage (garage on main floor, panel in walk out basement). To me, it was an easy install. Just run a short wire from the panel through the wall and install the charger on the garage side of the wall.
Easy, right?
But he says "no". He tells me that the Fire code doesn't allow for penetrating the fire rated wall between the garage and living space. He told me he could do it, but when I said I wanted a permit so I wouldn't have any insurance problems, he said it wouldn't pass inspection.
I can't be the only one with a panel inside and wanting a charger in the garage. What did other people do?
boaterva
7,562
3,736
Northern Virginia, USA
Easy, right?
Don't you have other circuits to the garage? How did they get there? Even if this is so (the 'can't penetrate') there has to be a way to 're-seal' the hole made for the conduit/cable.
I'd find a better electrician.
bcsteeve
647
651
Kelowna, BC Canada
Yes, but they don't go through the wall. They go up through the ceiling into the shared attic space and then down the walls that don't border the living area. No circuits are on the wall meeting the house. I could do the same thing with the charger but a) the house wall is by far the most convenient for use as a charger and b) it'll be hella expensive. That 6/3 wire is pricey!
Odd thing is... there's a big messy hole for where they "plumbed" in the pipes for the central vac. That might have been done by the previous owner, I don't know.
How do you "re-seal" a hole if it has wires going through it? Wouldn't he know about that? His card says he's a Red Seal certified electrician... isn't that the best? But you're right, no harm in getting a 2nd opinion.
[edit]: I see Red Seal is a Canadian-specific thing, but yeah it pretty much is the Top Gun of trades.
boaterva
7,562
3,736
You seal it with whatever is code. Seal means it's fire-rated. That's all we're talking about. I'm not even clear on what code violation we have here... people have garages and internal breaker panels all the time.
In any case, if this is an actual code necessity, you may be weighing the cost of the extra copper (wire) against the time and materials to seal the hole and issues if an inspector doesn't agree. If there is a way around it, perhaps that's better.
I still don't see how 'going over the wall' is okay and going through it isn't, Seems like a hole is a hole! :D And, yep, on the vacuum. If that's the actual vacuum line, that's a lot more of a fire hazard (open air channel) than a power conduit.
I'd definitely get a second opinion, and maybe ask them for a code citation from NEC. (Whoops, didn't see this was CA.. All of this could be Canadian 'issues'. :D )
Reactions: redy and Nda721
aesculus
Still Trying to Figure This All Out
May 31, 2015
4,314
2,465
Northern California
I would take pictures and a drawing to your local building department (the people who will do the inspection). Ask them what they would suggest. In many places they would prefer a little up front inquiry rather than having to upset a homeowner and remove improper work later.
setipoo
Breaker of Chains and Mother of Dragons
May 3, 2017
177
622
North of America
Get a 2nd opinion. I had the same situation and it's an easy solution to drill through and seal a fire-rated wall into an interior room.
Cyclone
Cyclonic Member ((.oO))
Jan 12, 2015
5,056
1,141
Charlotte, NC
@bcsteeve , your setup is exactly like mine, except I'm in the U.S. I also have existing 120v outlets in the garage fed from wiring going up by that "shared" wall. Not a problem at all here. I agree with others about getting another opinion, though the suggestion to ask the inspector's office first is a great idea.
bcsteeve
647
651
Kelowna, BC Canada
Almost 10 at night and I just got a reply back from another electrician I emailed. He said he should come look, but basically called the other guy nuts because in this jurisdiction there's no special fire stopping / rating between the garage and home at all... just normal 1/2" drywall. Here's his exact wording:
Your fire stopping concern, unless your house has a legal suite, nothing in it will be rated for more than the typical 30 minute rate for 1/2" drywall. A fire rated wall needs to have double 5/8" drywall in order to be classified as a fire wall. All houses are finished using 1/2", even the garage and nothing in side of them, plugs, switches, lights, garage opener, have been fire caulked for that rating. So a wire penetrating through the drywall won't matter for fire. You might want to caulk around the wire after it is complete to reduce the potential of any carbon monoxide from creeping into the panel room, but that is about it.
I'm a little worried that I've gotten two polar opposite answers from two local fully licensed electricians.
However, guy #1 was here while guy #2 is going by email. On the other hand, guy #2's answer makes a lot more sense.
I'll know soon enough. He's coming tomorrow or Friday to take a look and confirm it is what he thinks it is. I suppose if he does the work and it fails inspection that that's on him, right? Or is that a bad assumption?
[update]I looked up guy #2... he's not only Red Seal but also certified by the authority which does the inspections as a person who does inspections. I wonder if he's allowed to inspect his own work? Lol
mandersen
91
66
Woodinville, WA
I'm a little worried that I'd get two polar opposite answers from two local fully licensed electricians.
Just get a bid and make sure he includes verbiage around "Will be installed according to all local electrical codes and will include passing the inspection" Or something along those lines and go with #2 :)
Reactions: Cyclone
stopcrazypp
9,891
4,814
If you want to be sure, you can always just ask your local building department, perhaps even your actual inspector (looks like there is a designated one per area).
Inspector area
bcsteeve
647
651
Kelowna, BC Canada
That's for building permits. Different animal. But your point is the same, and yes I will phone the Authority tomorrow and see if there's a local office I can go run this past.
I don't know how it is for other places, but here we have something called the BC Safety Authority which is responsible for permitting and inspecting electrical and gas in *most* (not all) areas of the province. I always thought they were a government body, but today I learned they're private and have been empowered by the province to do what they do.
stopcrazypp
9,891
4,814
Okay, your area operates different than here in California. Here, the local building inspection department for a given city/town handles all permits within a city/town (building, electrical, gas, plumbing, etc). There is no special separate statewide body that does this.
