and I would not need the wall charging unit at all? If so, what added function is provided by the wall charging unit?
And just to catch up with an answer to this last question of differences and pros/cons of mobile charge cable versus wall connector. First off, if you want to see a lot of discussion on this search this forum for "UMC vs HPWC". Those names were the Universal Mobile Connector versus the High Power Wall Connector. I think the second one is just called Wall Connector now, but those acronyms were used for a few years, so there was a lot of discussion there.
So no, there isn't any actual
need to get a wall connector at all. I've had my Model S for 4 years, and my UMC stays plugged into a 14-50 outlet in my garage, and it hangs nicely on a hook on the wall. I don't unplug it or put it in the car every day--no need. I can't use up 200 miles driving around town in a day, so there's never any purpose to having it in the car around town for daily use. And even if a charging situation would come up, that UMC is only used for plugging into an
outlet. When would I really be charging from an outlet in my local area? The Superchargers, CHAdeMo stations, and J1772 stations don't use that cable anyway. So it's just not really going to come up in daily use. So I would only take it with me if I am going out of town on a road trip a few times a year. And even with that, most of the time you wouldn't even need it if the route is well covered by Superchargers.
But...the pros and cons are:
Some people absolutely insist on being quadruple prepared for every form of emergency, so they MUST have the UMC in the car at all times in case of zombie apocalypse or whatever. In that case, you really won't want to plug and unplug every day, so you would need to get another [something] to keep at home to charge. In that case, with both UMC and HPWC being close to the same price, yes, I would absolutely recommend the HPWC as a permanent at-home item.
(1) Higher power capability -- I don't run my mobile cable at the maximum 40A, because that is the maximum for the cable wire thickness and electronics in it, and it gets kind of warm doing that, so my amps are turned down a little. The wall connector is beefy, and can handle much higher loads, so there's more margin there at whatever level you're running. Plus, it can go on higher circuits, like 60A or 80A, to give you more of the charging speed that the car can handle.
(2) Lower power capability/flexibility -- It may sound a little odd, but this is still a good use case. Some people with very small electrical services may only be able to add a small 240V circuit, like a 15A or 20A or 40A. There isn't a 40A outlet type, so it's a little hokey to deal with that, and you would have to buy Tesla plug adapters for those other outlet types anyway, so the wall connector is a good solution that will fit whatever you have now or in a different house someday.
(3) Power sharing -- If you do later end up getting a second Tesla, the wall connectors can be installed and connected together in a certain way to communicate in order to share the power from one size of circuit, allocated dynamically as the cars need it. Pretty slick if you end up needing that someday.
(4) Hard wired/less connection points -- This is just a small improvement in safety. The less plug points and interconnections the better, so for a long term permanent thing, the hard wired wall connector is solid.
(5) Looks like frickin awesomesauce! -- You have a futuristic kickass electric car! It's kind of cool to have a piece of Star Trek technology mounted on your wall, and the cord wraps neatly around the body of it, instead of looking like a bulky extension cord plugged into an outlet and hanging on a hose reel you have screwed into the wall.
