Alberta Canada doesn’t have offer anything whatsoever as majority still heavily favour our oil here.Check your local municipalities for rebates.
My county only offers enough to purchase the charger but not the installation.Alberta Canada doesn’t have offer anything whatsoever as majority still heavily favour our oil here.
What settings do you have on your HPWC? 6/3 Romex is rated at 55A which means EV charging at 44A max. You need to set your HPWC for a 50A circuit which means 40A charging. Just because 48A is less than 50A doesn't mean it works that way.We had a 50 amp circuit installed with a NEMA 14-50 plug (Romex 6/3, wish I had gone with 4/3 but too late now). Originally I was using a Clipper Creek HSC-50P corded EVSE but after selling our Volt I opted to buy a new Gen 3 WC and add an appliance cord to it so I could retain the 14-50 plug should the WC crap out.
I will update the outlet as the one they installed looks generic. But since I don't plug and unplug the WC I'm not stressing it.
My cost during construction was $300
One last thing. Take a good look at Solar. See this link for details. Looks like about 5 years return on investment and No Electrical Costs For The Rest of Your Life.Thanks to all for your posts here and especially @Tronguy for the very detailed information.
I just recently took delivery of my new Model Y and I’m about to begin construction on a new home — I know practically nothing about electrical work so this thread has been super helpful. Thank you!
I would ask them to run cable for a 60 amp connection. That way you can install a 14-50 (Industrial grade - not Leviton) with a 40 amp breaker for 32 amp draw with the mobile charger. You will be able to upgrade to a wall charger if you wish by replacing the breaker with a 60 amp, removing the 14-50 outlet and installing the HPWC right over the outlet hole using the stud that is already there. That's what I did anyway...What do I need so I can charge a Tesla Model Y?
On Tesla’s website, I see Wall Charger and NEMA 14-50, would either of these work? Do I just plug it in the outlet and will charge Tesla?
Edit: The builder builds houses with these EV charging outlets included so I assume they are 240V
Doesn't 5 LED's illuminated mean the charger is turning out 48 AMPS through a 14-50?
No. Congress did not vote to approve an extension or renewal of the Alternate Fuel Vehicle Refueling Property Tax Credit that expired at the end of 2021. Check with your local utility for any rebates.Is there a federal tax credit or refund of 1/3rd of your EV charger costs including installation costs?
Actually Tesla recommends a 50 amp breaker for the 14-50I would ask them to run cable for a 60 amp connection. That way you can install a 14-50 (Industrial grade - not Leviton) with a 40 amp breaker for 32 amp draw with the mobile charger. You will be able to upgrade to a wall charger if you wish by replacing the breaker with a 60 amp, removing the 14-50 outlet and installing the HPWC right over the outlet hole using the stud that is already there. That's what I did anyway...
