Burnt nema 14-50 plug and breaker tripped
gilscales
1,684
1,897
Long Beach, CA
It's not. The UMC is definitely the weakest link. I've killed 2 and the 14-50 outlet is still standing strong.
I have only used the UMC on road trips at my brothers house, I have the HPWC installed at my home and set it to 32A as this is plenty so I really have no idea how well the UMC holds up or what is causing yours to die when others here have mentioned that they have been using them for years without issue?
nwdiver
7,432
9,441
United States
Gen 1 could do 40A. The internal connections for the adapter are not very robust. Both of my UMCs melted at this point. I suspect this is one of the reasons the Gen 2 UMC is limited to 32A. Heat from current is I^2 so 40A generates ~60% more heat than 32A.
gilscales
1,684
1,897
Long Beach, CA
Makes sense, so now you are using a gen 2?
nwdiver
7,432
9,441
United States
No. I have a 'hardwired' UMC. It's a Gen 1 that doesn't have adapters. It's a permanent 14-50. I also charge at 20A unless I need to charge faster....
Reactions: eprosenx
dhanson865
4,345
5,734
Knoxville, Tennessee
On my second overnight charging I received an alert from Tesla app which told me that charging was interrupted. I found that the breaker tripped and the NEMA 14-50 outlet and plug burned. See the pic below.
Thanks for posting all the gorey details and pictures. These sorts of issues are common, but every new example makes it easier to convince the "oh that never happens" crowd. Maybe at some point it'll be common sense to look for these sorts of failure modes before it gets to the scorched components point of post mortem.
gilscales
1,684
1,897
Long Beach, CA
The Leviton 279-S00 (Home Depot special at $9) is not the best made outlet (Even though now it is rated industrial duty) it does not compare to the 2 Tesla recommended outlets (IMO)
Just look at the contact blades of the Cooper 5754N vs. the Leviton 279-S00, also the the terminals on the Leviton do not use the clamp style for the hot legs, its just a large screw that when tightening can damage the copper wire strands because you will be applying a twisting force as the screw end bites into the wire, both brands tighten terminals to 25 in-lb. so if you really want the BEST 14-50 Receptacle then go with the Hubbell HBL9540A as they use 3/16" Allen screws for 75 in-lb. rating and have large copper V shaped lug boxes
eprosenx
2,065
2,481
Beaverton, OR
Thanks for posting these.
So you have me at the screw terminal. I hate screws into wire. Clamp terminals are so much better.
Where did you source these from and how much were they? I need to find good cost effective places to buy the better receptacles.
gilscales
1,684
1,897
Long Beach, CA
Someone else on this forum posted that the Cooper 5754N could be had for $12 and I was finding that hard to believe as prices tend to be in the 50$ plus range everywhere else, I used the link provided by the post and received the real deal for that price, however, I still believe that the Hubbell is far superior to the Cooper.
Here is the link to the place where I purchased the Cooper
Cooper Wiring Devices - 5754n, Straight Blade Receptacle - Dale Electric Supply Co.
gilscales
1,684
1,897
Long Beach, CA
Those are on backorder.
Their site shows 3 in stock, I placed an order for 5 of these on 12/5 from the website, I received a call from them the next day informing me that they had 2 in stock and that the other 3 would have to be backordered, they asked if I would like to wait until the backordered items arrived so that it would be less for shipping, I agreed and the package of all 5 units arrived yesterday, they may be backordered but it seems they can delivery them quickly anyway, at least they did for me.
gilscales
1,684
1,897
Long Beach, CA
So order one and see if you get the same email I did. How on earth are you going to need 5? Or are you just reselling them on Amazon?
As @MP3Mike has stated already I am a General Contractor and just bought some stock, if you would like one then I will send you one as I do not need all of them at this time, just P.M. me and i'll send one at cost plus my shipping cost if you like.
