I am talking about EV charging back in the 1990s, where AVCON (aka J1772-2001) was designed for "6.6kW" charging based on 220V 30A. Even later, the Leaf had "3.3kW" and "6.6kW" chargers based on 220V 15A and 30A.
Are you stating an 'official nameplated' voltage or did you just surmise the 220 volt rating? Yeah its true, GEN 1 voltec (GM) systems needed 220 volts to get the full capacity, although GEN II systems (allegedly 7.2 kw) need 225 Volts to get the 'rated' power level. But then, those cars will charge at least at 7.7 kw with 240 - (I haven't been able to test my GM with anything higher as of yet). The Tesla Roadster I had would run at 16.8 kw at 240 volts, and modern Teslas used to be advertised as having 10 kw single chargers and 20 kw dual chargers (which would only happen at 250 volts - of course, the car itself COULD be charged at 277 volts - since I never had a 'modern' Tesla I don't know whether the power level plateaued at 20 kw and the current started dropping beyond 250 volts, or if the power level just kept increasing..
Even though the 80 ampere dual charger "S" 's were very popular, its a bit ironic that the battery size has kept increasing and Tesla is starting to release larger vehicles (Model "X", etc) - yet the standard rate has been dropped from 40 amperes to 32 (I'd say due to too many problems with the standard charging cord at 40 amperes, yet of course they'd never admit it), and the absolute maximum charge rate of 48 amperes on ANY Tesla (excepting the SEMI of course).
****update***** Just checked the Tesla website - apparently they have RERELEASED the 72 ampere charger for the 100 kwh vehicles. Too many must have complained that 48 amperes was simply not enough. I'll have to check if the website was just talking about 'historical' vehicles, or whether the 72 ampere product is now newly available again for new customers.
*****update 2**** On the model X portion, the present limitation is still 48 amperes, so the 'charging portion' must therefore refer to charging those USED model 'x' 's that had a 72 ampere charger. They also claim 200 kw (!!!) at the most modern Superchargers.
Yeah there are now SC's available, yet Mr. Musk has warned owners not to hog the local facilities and to charge at home when possible. I privately think he got some backlash from electric utilities threatening to put Demand Fines on residential Tesla customers since most utilities insist that EV's should use the ENTIRE after midnight period (12- 8am). to recharge - since 40 amps at 8 hours is much easier for them to accomodate than 80 amps at 4 hours (PER CAR), and its not a problem if a neighborhood only has 1 or 2 Teslas, yet a subdivision full of 80 ampere Teslas would cause a UTILITY indigestion as having to provide larger facilities for zero additional revenue over each car being 48 amperes maximum - the present limitation. And of course Tesla has handled the multi-car problem by throttling the HPWC to a premises maximum of 24-80 amperes (user selectable) even if the very large home has up to 4 HPWCs.
But 220 volts is usually generous for most public chargers - they being distant from any electrical services and electricians rarely if ever taking into account pressure drop over long distances from the main buildings, such that some here have said they have charged on as low at 183 volts, it is also true that 195-199 volts isn't uncommon at all.
Now as far as the 3.3 kw GEN 1 LEAF was concerned - a friend would get 18 amperes on a horrible public docking station (184 volts). Since Japan is universally 100/200 volts whether in 50 or 60 HZ areas the GEN 1's EXCELLENT low voltage performance was to be expected. Does anyone know whether the 6.6 kw later chargers would draw an analogous 36 amperes? The largest wall box I have is 32 amperes but I have yet to have someone with a GEN 2 Leaf try it out to see if the charger can hack more than 30.
