Hey folks,
After using Scan My Tesla for a bit, I've made a number of interesting observations that I don't think have been outlined before. These behaviours might be new as well. Reporting as of firmware 2020.4.x.x and in relation to public chargers (via J1772 adapter).
Myth: Being plugged in will only use power from the wall for various functions.
Reality: Even when "charging", the net power on the battery can actually result in losing charge. There is no way via the built-in display to see how much you're losing either.
Myth: Preheating the cabin won't draw energy from the battery when plugged in, thus not putting wear on it.
Reality: Extremely false, unfortunately. This is twofold: the net power drawn can exceed the amount given by the charger, and the power runs through the battery first anyways. This does not "save" your battery or limit climate control power.
Myth: After charging is completed, climate control power will come from the charger.
Reality: This is... partly true? Sometimes it re-engages charger power, sometimes it disconnects, and this can change every minute or so. As above, it's all running through the battery anyways.
Myth: The battery is not heated for Level 2 charging (i.e. not Supercharging, regular public chargers).
Reality: I was surprised to see it does actually heat the battery. It's not by a lot and the temperature varies a bit, but it will be kept above 10C (50F). If you use percentage for displayed capacity, you can't see this. If you use distance, it will report as 0mi/hr or 0km/hr (or some lower than expected number) while the battery is being heated.
Myth: The battery does not heat itself when parked in the cold.
Reality: It does! This is very hard to catch and I have almost no data on it, and that data may be confounded (e.g. I was close to the car with my phone key, car seemed awake). More data needed. Basically, I need to be in a much colder area to test this.
Recommendations/Tips:
Bonus observations:
Hopefully this was helpful to someone.
- Use "Distance" for energy display in order to tell what's going on. "Energy" will show something like 7kW even if all of that is going to battery heating, while "Distance" will appropriately adjust the number of distance units being added. However, for Level 3 charging (Supercharger/CHAdeMO) the kW rate is actually correct and represents net power being fed to the battery.
- Be aware that energy used for climate control is still using/wearing your battery. There is no way around this.
- All types of charging need to warm the battery. In the case of at-home or public Level 2 charging, it won't charge at all until the temperature threshold is met. Keep this in mind if you're tight on time.
- Your battery is colder than you think if it sat outside. You can be needing to run the AC because the cabin is too warm from direct sun, while your battery is nearly freezing in the shade of the rest of the car.
- You don't need to turn off climate control at an L2 station, if your goal was to allow more power for heating the battery. It will simply draw more power from the battery for this rather than capping power draw to the charge rate.
- Don't drive around trying to preheat your battery prior to an L2 stop, just to avoid the preheat period when plugged in. This is a larger waste of time and energy unless you're getting something else out of the drive.
- Regen limit has nothing to do with whether or not your battery will be heated at an L2 station, only temperature.
Bonus observations:
- The front motor is used for regen below about 14 mph (iff you were accelerating prior), otherwise it's always the rear motor.
- Drive mostly uses the rear motor. Reverse mostly uses the front motor.
