If most of your driving is city, or congested (significant stop and go, or speeds under 65), the Volt will most likely do all your commuting chores on just electricity, even 120v. Look at Chart 2 and double the numbers.
https://www.rita.dot.gov/bts/sites/...s/omnistats/volume_03_issue_04/pdf/entire.pdf
Common city range:
2011-2015 (G1) 40 miles ±4mi
2016-2018 (G2) 60 miles ±6mi
Because of this it is not usual to go months without a visit to the gas station.
Unlike most hybrids, it has full passing power without using gasoline. Which is more passing power than the Leaf or Priuses (any) by a good amount. There is zero lag in pedal response, and a full 60kW regen on tap. It also handles better than most cars in it's class.
Freeway range at 101 mph (limiter) is roughly 50% of that, but by using the generator, you can go about 200 miles at that speed.
Common city range:
