Buying a used Model S, what to look for?
Discussion in 'Model S: Ordering, Production, Delivery' started by Jeddi, Sep 5, 2013.
  1. Jeddi
    Jeddi Member
    Hayward/Tahoma Ca
    I've been reading endlessly about Model S for several weeks now. Looks like I may have found a winner (slight used 2013 P85+).
    What are some things to look or research while inspecting the car?
    I'm assuming the factory warranty is easy to transfer and it should cover any warranty related issues.
  2. jerry33
    Texas
    There is little to look for compared to an ICE car. Check the 12V battery voltage and inspect for physical damage. The warranties are transferrable (There is a $100 fee for transferring the extended warranties.)
  3. Cheerose
    Cheerose Member
    Las Vegas, NV
    I don't have the link handy (and will probably need it soon), but there is a checklist that someone has come up with regarding a new delivery. You would probably be able to follow it as well...
    Assuming that this is not coming from Tesla, you'll probably not get a walkaround done by the seller -- Therefore, you should watch the walkthrough video online to better "prepare" yourself.
  4. Lump
    Lump Active Member
    So. Cal.
  5. Jeddi
    Jeddi Member
    Hayward/Tahoma Ca
    I have read through the checklist and watched factory provided video.
    How and where can I inspect the 12V battery?
  6. GasDoc
    GasDoc Member
    SF Bay Area
    As you face the Frunk from the front of the car, the battery is in the upper left hand corner under the air intake.
    The battery is visible in some photos in this thread. There is some disassembly involved before you can visibly see the battery. I wouldn't expect the owner to let you do this.
    You'll want to see a red 12v battery. The grey ones had issues and Tesla had to switch suppliers.
    You may also want to inspect the inner aspects of the rear tires for excessive wear due to the high amount of negative camber in the suspension.
  7. Jeddi
    Jeddi Member
    Hayward/Tahoma Ca
    Great info. Thank you.
  8. AudubonB
    AudubonB Mild-mannered Moderator Lord Vetinari*
    Make absolutely sure the mandatory oil-change interval was strictly adhered to.
    With the proper SAE grade oil, too.
    And oil filters, and fuel filters, also.
  9. brianman
    brianman Burrito Founder
    Be wary of subtle humor with relatively new members...
  10. Jeddi
    Jeddi Member
    Hayward/Tahoma Ca
    Yeah and I'll make sure to get the smog check done too!
  11. brianman
  12. AudubonB
    Note to relatively new members: Be wary OF ANYTHING that that whack-job Audubon writes. Fairly warned.
  13. brianman
    Hehe.
  14. Laumb
    Laumb smrtass.
    Lost in Norway
    Just pop the nosecone. There is a positive and negative terminal there - should at least make you able to measure voltage.
    Id tell the seller Im disassembling to check the battery - ask if he wants to help.
  15. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    4 wheels. it should come with 4 wheels. and some lug nuts too. you're probably SOL for cup holders though.
  16. William13
    William13 Active Member
    South Bend
    These people are pulling your chain.
    A P85+ has a good 12 volt battery. There is no way for you to evaluate it. Even checking the voltage will not tell you anything. The car is new.
    Confirm car fax. i.e. no accident.
    Inspect for damage. Esp. Curb rash on wheels. Scratches. B pillar wear. Dent on frunk. Scrapes on bottom of battery. Be sure the body panel alignment is good enough for you. (It won't be perfect.)
    Check tire wear. Inside rear wheel tread.
    Ask for permission to check with Tesla that only normal (non trauma related) repairs have occurred. Confirm this is a P85+ with VIN. Confirm what warranty goes with the car and who is paying for transfer. (Do it yourself if allowed.)
    Drive the car on a bumpy road to check for creaking. There should be little to none.
    Bring your wallet. You will buy the car.
  17. brianman
    Oh goody. I have a question now!
    How do you confirm via VIN that the vehicle has the + option?
  18. yobigd20
    Skaneateles, NY
    you can't. looking at full VIN numbers of P85+ vehicles and comparing them to mine they are exactly the same except for the last 5 digits which are the production sequence numbers.
  19. brianman
    That was my recollection as well, hence the question.
    I guess what William13 really meant was "confirm the P via the VIN" and "confirm the + by the rear wheels/tires and by consulting with a Tesla service center to check the suspension".
  20. lloyds
    lloyds Active Member
    Bay Area
    Interesting things to look for. Now this begs the question. Does Tesla offer to potential pre-owned (private) buyers a PPI option?
