Buzzing at low speed
Discussion in 'Model S: Driving Dynamics' started by Brightonuk, May 14, 2014.
  1. Brightonuk
    Brightonuk Member
    Plantation
    I hear a distinct buzzing when easing on the throttle up to about 20mph after that it fades out. I assume it is coming from the motor as it seems to originate from the right rear (passenger side of the car)
    It is not overly loud but loud enough to be an annoyance.
    Any ideas?
    Thanks
    Steve
  2. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Just taking wild guess...
    1. Did you rule out it's not related to your cell phone? Some have reported certain cell phones create interference ....
  3. Zextraterrestrial
    Humboldt/Los Altos
  4. stacyh3
    stacyh3 Member
    Ann Arbor, Michigan
    I'm hearing a similar noise when I accelerate or decelerate at highway speeds - 50-70 MPH is when it's most noticeable. It's a noise that I never heard before. If it's the inverter, is this normal wear and tear, or should it be serviced? My car just turned a year old and has about 17,000 miles on it. The first annual service was done a few weeks ago.
  5. ckessel
    ckessel Active Member
    I had to have my inverter replaced for something similar. However, it was only on deceleration I really heard it, basically only when regen kicked in (kw went red->green)
  6. Blurry_Eyed
    Blurry_Eyed MS Sig #267, MX Sig # 761
    It also might be the audio speakers buzzing. Have someone sit in the back and try to listen to the speakers in the doors to see if it's coming from there. If so, there might be a loose wire or connection somewhere in the audio system. But it's more probably that it's related to the inverter.
  7. Brightonuk
    Brightonuk Member
    Plantation
    Thanks
    Not the cell phone but possibly the speakers I will check that scenario out today.
    If it is the inverter is this something that I need to be (overly) concerned about?
    Although this happens at low speed if I push the car (plan to take it to the track this weekend) could it compound the issue?
  8. wycolo
    wycolo Active Member
    WA & WY
    Need to crank up your tunes, man!!
  9. DA808EV
    DA808EV Member
    SoCal
    I heard the same thing y'day. Was parked for about 15 minutes and as I left and turned on the AC, heard a loud buzzing and had to mute my music for a few seconds just to make sure it was my car. It went away though after about a minute.
  10. FlasherZ
    This is a known noise. Occurs between 10-20 kW of consumption, typically. Those with finely tuned ears can hear the gentle buzzing as you give it some power, but to hear it well, roll down the windows and go through a tunnel or in a parking garage.
    I know several owners - as well as I - have reported it. It developed in my car around 20k miles. As I understand it, it is considered "normal" behavior by Tesla.
    - - - Updated - - -
    This is different - that is likely to be your A/C compressor.
  11. Brightonuk
    Brightonuk Member
    Plantation
    Yep that worked thanks
    The guy in the convertible and bad toupee did not seem to enjoy the Sex Pistols @ 185dBs
    But the buzzing has disappeared
  12. Duckjybe
    Duckjybe Member
    Ontario, Canada
    I had this exact issue in my car. Light throttle at low speed produced an electrical buzzing sound coming from the vicinity of the rear right. However, I also had a very noticeable humming sound from the inverter on the highway. My drive unit was replaced last summer.
  13. Zextraterrestrial
    Humboldt/Los Altos
    yes this sound.
    I wonder if it is the inverter getting 'broken in' and harmonics starting in the coil? This range of power consumption is right around the average overall power draw when driving, something like ~15-25kW or so for typical cruising. there is a level of acceleration that I can push the pedal to make the inverter sound kind of pulse, sort of like the sound of a Kitchen-aid mixing really stiff dough
    Living in Humboldt I know that old grow lights would begin to buzz louder and louder, not sure if the inverter is similar maybe? New lights have some sort of digital inverter set up now
  14. FlaSteve
    FlaSteve Member
    Lake Worth, Fla
    I heard the exact thing. Turned around and asked my wife to please move to the front seat. Now the buzz is in the ...
  15. cinergi
    cinergi Active Member
    MA
    Same. My drive unit was replaced a while ago and the noise went away. It's back now. And if considered normal that sucks because it's really noticeable with the windows down. I wonder what it sounds like to pedestrians. I'm about to call it in - same service manager as who dealt with it before so we'll see what he says.
  16. bhuwan
    bhuwan Active Member
    Boston, MA
    Let us know what he said. Mine is noticeable and has been for a while.
  17. linuxdrake
    linuxdrake Member
    Rhode Island
    Same here as well since Update to 5.9 I hear it much more than before, loud wine from 10-20kw drain.
  18. Andvib
    Andvib Member
    Norway
    I have the same buzzing sound from right rear. 5-25kW. Its not loud though, rest of family cant hear it unless I tell them to:) I find the noise annoying, service techn. confirmed sound but said normal operating sound when test driving. started around 8k miles, now 10k miles.
  19. JohnnyMac
    JohnnyMac Member
    Silicon Valley, CA
    I now have the same buzz as well. Perhaps related to 5.9 as it has never existed previously. So, lets see, I now have the low power buzz, the gear lash clunk (when easing on and off the throttle at low speeds), and I have the ever so lovely high-pitched balloon squeal under heavier acceleration. All of these are "normal" according to Tesla. That is a whole lot of normal sounds. Nots even sure what else there is that could develop next, but all these "normal sounds" are growing tiresome in totality [Sigh + head shake].
  20. nrcooled
    nrcooled P#8946 VIN 03225
    NoVA
    I had this same issue. I took the car in for tank mode and mentioned it along with the drone at highway speeds (over 70mph for extended periods of time)
    Long story short, I got a new drive unit. All noises are gone now.
