Which sorta brings us full circle, Jerry! Just what is fake food? If a naturally-occurring substance like seaweed is reformulated through a chemical process, and it is added to other foods to provide flavor, texture, body, or anything else, is this or is this not fake food?
I don't believe I've used the term "fake food". The processed food that causes problems is high in sugars, salts, saturated and trans fats, with little fibre. Much of your diet should consist of whole grains (once you start grinding your own grain to make bread, etc. you'll never go back to store bought flour), lentils and beans, vegetables (Sweet potatoes and yams vs regular potatoes is an example of an easy change to make a meal healthier), and some fruits.
Items like gelatin are really a small part of any dish that uses gelatin.
The
Harvard Healthy Eating Plate is a good place to start. It's main issue is that it still talks about "servings". And most things that aren't all that healthy need to be ingested either regularly and/or in large quantities to cause issues--unless you have allergies but that's a different topic. Unfortunately, the supermarket is full of processed and sugary foods, so it's very easy to eat them regularly and in large quantities. To make it worse, if you look at the serving size on the nutritional information it's often about 10% of what a person would normally eat (no one eats three potato chips and stops).
The usual excuses:
I don't have time. It takes me about two hours to cook a meal. However, if I cook a large batch, it still takes two hours but I've cooked enough for a few days.
There are only two (or one) of us so there is a lot of wasted food. If you cook a large batch, you'll use all the ingredients so no waste. Many things can be frozen and eaten later.
Now baking bread takes three to five hours, but most of that time is just waiting. There's maybe 30 minutes of active cooking plus ten minutes to wrap the bread for freezing. I make a dozen loaves at a time which lasts about 24 days.
Now it does help if you have some real equipment so the cooking is fun rather than a chore:
1 A wall oven so you don't have to bend over (Bluestar is what I have)
2. A copper sink, single bowl, with ledges, cutting board, and colander holder. (keeps the mess in the sink and practically no cleanup). (Rachiele in our kitchen)
3. A very good mixer (Ankarsrum is what I have)
4. Grain mill (KoMo is what I have)
5. A very good knife (such as a nakiri) and a couple of stones to keep it sharp
6. A pressure cooker (so you don't have to soak the beans. MultiPot 9-in-1 is what I have)
7. An induction cooktop (uses 80% less energy and is very controllable)
8. A good set of pots and pans (Fissler works very well, some of the others, like All-Clad have flimsy bottoms that warp under heat). You don't need very many. one of Each 10qt pot 7qt pot 12" pan, 5qt pan, 7qt pasta pentola
9. Three or four full size baking sheets
10. Four or five full size cooling racks
11. Large strainer and a set of small strainers
12. Pizza peel
13. Digital thermometer
14. Digital cooking scale
15. 9x5 bread loaf pans (12 of these)
16. 13qt mixing bowls (3 minimum)
17. 20qt mixing bowl (1)
18. Several sizes of glass prep bowls. 3-6 of each
19. Spice grinder
