CA FasTrak Transponders
Discussion in 'Model S: Driving Dynamics' started by Michael M., Jul 16, 2015.
  1. Michael M.
    Michael M. Member
    Los Angeles
    My FasTrak transponder is/was correctly installed at the top/center of the windshield. However, any time I use the FasTrak lane, my account is charged because the the system cannot read the transponder through the coating which Tesla puts on the windshields. The last time this happened I called Metro Express and they credited my account back. Today, I apparently reached the correct person. She stated that they are aware of this problem for the Tesla and that she was putting my license plate on the "exclusion" list. This means that from now on whenever I use the FasTrak lane the system will still photo my license plate, but then it will not charge me. My license plate is now permanently excluded. I will be removing the transponder now since I see no point to keeping it up there on the windshield. Of course, I still have to pay the $1 monthly fee, but at least I no longer have to worry about the transponder or figure out a work-around.
  2. David99
    David99 Active Member
    Brea, Orange County
    That's awesome! I had no luck with the old FasTrack transponder. But the new one with the three way switch works great.
  3. Michael M.
    Michael M. Member
    Los Angeles
    Mine has the three-way switch but still isn't transmitting through the windshield I guess.
  4. anxman
    anxman Member
    san francisco, ca
    Mine has never worked through the windshield. Same with my condo garage opener. I just manually stick them out the window.
  5. JPP
    JPP Active Member
    SF Bay Area, CA
    #5 JPP, Jul 16, 2015
    FWIW, I had been using an external likcense plate FasTrak transponder here in the SF Bay Area, as I could never get the internal version to work. I had this mounted on the black front bumper bar behind the nose cone. Worked great.
    There are soon going to be new HOV/flex $$ pricing lanes here, so there is a new internal FasTrak Flex transponder with a 3 position switch. 'Ordinary' drivers set the switch to the number of occupants and use the bridges/toll lanes, and are supposed to be billed as appropriate. But what about the shielded Model S windshield--what could I do?
    I went over the Bay Area FasTrak web site and read up on the system, and also spoke with a representative. If you have the white HOV stickers and thus qualify, you can get the new FasTrak Flex transponder and leave it set to 3. So I got the new transponder, set it to 3, placed electrical tape over the switch and the speaker opening, and also taped up the enitre perimeter of the transponder case. I then popped my nose cone off, deinstalled the old license plate transponder, and Velcroed the new one to the inside of the nose cone itself. I have not yet hit a HOV/variable pricing lane yet. YMMV.
  6. TTT
    TTT Member
    San Diego
    #6 TTT, Jul 16, 2015
    Hmmm, first time I've heard of this problem. I have an old Fasttrak transponder and only lay iy on my dash without any problem
  7. Ed Chan
    Ed Chan Member
    Palos Verdes, CA
    Wow, that's news to me... Did you call 511 to get connected? I've never had any luck with talking to them. Anyways, I say this in any So-Cal Fastrak thread that comes up -- I found that mounting on my rear glass (or just velcro to the underside of the parcel shelf) works 100%. I've driven dozens of times up and down the 110, through the 73, and even in the bay area on the Golden Gate Bridge and it's read 100%.
  8. apacheguy
    apacheguy S Sig #255
    So Cal
    Never reads thru my windshield. If you have your license plate registered on the account then you shouldn't need a separate exclusion. It should be automatic. That's the way it's always worked for me at least on the toll roads.
  9. Michael M.
    Michael M. Member
    Los Angeles
    I think you are lucky that you weren't charged. Perhaps they put you on the exclusion list to begin with.
  10. Michael M.
    Michael M. Member
    Los Angeles
    I did get to a human through 511. Never thought about mounting elsewhere but since I also have ceramic tint I'm not sure that it would work in other spots as well unless it was inside the nose cone.
  11. WarrenInCA
    WarrenInCA Member
    Scotts Valley, CA
    Thanks for the heads up on the Flex transponder. I ordered one this afternoon!
  12. cryptyk
    cryptyk Member
    United States
    All very interesting. In San Diego, we don't need transponders for EV vehicles. You just put on the decal and drive.
  13. Michael M.
    Michael M. Member
    Los Angeles
    You don't need it for the regular HOV carpool lanes but if you want to take the toll road up to L. A. then you need to get the transponder. It will cost you $25 plus $1 a month. You can get them from AAA and some Costco stores. If you plan to drive in SF Bay Area then you need it for the toll bridges as well.
  14. smilepak
    smilepak Active Member
    Eastvale, CA
    Mount it on the rear windshield works?
    - - - Updated - - -
    Where in the nose cone did you mount the Velcro? I have the same issue. I got one of those transponder with the 3 position switch. I suppose when I get the white HOV sticker, I can leave it 3 all the time.
  15. spentan
    spentan Active Member
    SoCal
    91 Express lanes transponder with 1,2,3 people switch. I have it on 3.
    Free access to 91 Express most of the time and no monthly fee.
    And it works through my windshield
  16. smilepak
    Eastvale, CA
    Really? I have a 3 way switch and that doesn't seem to work either. Where are you mounting yours?
    - - - Updated - - -
    WHere are you mounting yours? Can you take a picture?
  17. Max*
    Max* Charging
    NoVa
    Tesla has been through a lot of iterations on the windshield, even in autopilot cars. Hence it works for some of you but not others.
  18. spentan
    SoCal
    Mine works when it's upside down,
    Pics in this thread FasTrak Transponder - Windshield Location
  19. JPP
    JPP Active Member
    SF Bay Area, CA
    I mounted it to the back side of the nose cone centered just below the location of the Tesla T.
  20. steph280
    steph280 Member
    Orange, CA
    So if I apply for 91 expressway's Fastpass, they will issue the 3 switch type that can be used on 10/110 carpool lane as well?
