Hi everyone, I’m confused by cabin overheat protection. It seems to be linked to the tilt alarm. One can’t work with the other. But my tilt alarm is greyed out (it’s on, just greyed out).
So how do I proceed ?
Thank you...when you turn Sentry Mode back on, will cabin protection stay on? I will do the experiment but I don’t know how long it will be before I leave the car sitting in the sunFrom my understanding, reading for this question all over the internet, you are right... First of all you need to disable Sentry mode from the car, and only then you'll be able to disable the alarm. By then, you'll be able to turn on Cabin overheat protection.
Roll the dice... I had the car parked at a lovely hotel in Banyuls on their Destination Charger for two days (no other calls for its use, no crime committed). Sentry was on. Cabin Overheat Protection functioned. If it hadn't, it could have been a tale as told by Adrian Kronaur (You born on the surface of the sun?...)So...it’s either or...got it
that was you..............I had the car parked at a lovely hotel in Banyuls on their Destination Charger for two days
How?You can have Sentry Mode and Cabin Overheat Protection enabled at the same time. I do that all the time.
There were two Tesla and one non-Tesla. One Tesla was always open. Some Volvo kept coming in to use the other one. No foulthat was you..............
Not sure if the US and UK/European software is different... well, I know it is... but vis a vis Sentry/Overheat ??? The manual makes no reference (yup, I read it) but two different techies here in Spain insisted that it had to be OFFYou can have Sentry Mode and Cabin Overheat Protection enabled at the same time. I do that all the time.
OK, I’m curious, going out to check right now!
Yet I have sentry on in general, with exceptions at home and the office, and cabin overheat works for me. I fail to see the relation.
I'd say that a cabin temp of 50C when the Overheat Protection is set to come on at 41C is definately NOT engaging with all the Sentry, Dashcam and Tilt stuff off as it should.Yeah, I just turned on both, in any order in the car, locked up, still on - I can do the same with the app - not seeing any sort of mode combination limits.
Unless the OP is saying it doesn't actually engage (vs. just being enabled through the software UI).
I've been experimenting with it and cabin overheat protection is very fickle. One workaround people that posted that works is to log out of the app and log in again if it isn't working. Also it helps to use AC to bring the cabin temp back down below the limit before enabling cabin overheat. If cabin was already well over the set point and you enable it, it doesn't seem to work.I'd say that a cabin temp of 50C when the Overheat Protection is set to come on at 41C is definately NOT engaging with all the Sentry, Dashcam and Tilt stuff off as it should.
