Me too.I am a net solar generator and my concern is fixed charges and shifts in high rate periods outside of when I generate. Some of my periods are grandfathered.
I thought demand charges were supposed to pay for those kind of things. Do you have to pay those in addition?
What did your condo end up deciding ?Each unit is billed separately. There are 3 tiers of consumption. Our EV pushes us into the upper tier where the total cost is $0.26 per KWh. A new transformer for the L2 setup I mentioned would be a new service. It would have had adaptive charging, so peak charges wouldn't really come into play.
July (16-17-18-19) daily maximum (GWh) : 877, 851, 876, 817
Sounds remarkably short-sighted. Are you sure you live in LA and not AL ?The board didn't want to cough up the $24,000 required to get the $48,000 rebate from the city. We already have 4 EV out of 75 spaces. My personal L2 is the only one available. I let others charge for $1 an hour when I'm not home. Lots of my time invested for nothing accomplished. Looking forward, we will not likely ever get an opportunity like that.
We may be neighbors. I live in Boyes Hot Springs. We also share a bankrupt utility that threatens to shut down power during fire season.Me too.
I’m on the east side and done lots of research on a way to have power when Pacific Graft and Extortion decides to turn of the power. Propane and battery storage are both expensive so not sure what I will do because we are on a well which means no power no water.We may be neighbors. I live in Boyes Hot Springs. We also share a bankrupt utility that threatens to shut down power during fire season.
Oops, forgot to post the SPV record chart...
Is total use going down because of distributed generation behind the meter or other reasons?For reference:
Total System Electric Generation
2018 total use was down on 2017 and 2016 so the rising solar implies a higher proportion of generation.
Contributory for sure but no accurate stats are availableIs total use going down because of distributed generation behind the meter or other reasons?
