California Supercharger Prices
Discussion in 'California' started by Resist, Oct 24, 2020.
  1. Need
    Need Active Member
    SoCal
    The SoCal TOU-D-Prime rate for EV charging at night is $0.16/kWh. If this actually continue, you are going to see superchargers pretty full at night and morning.
  2. tij664
    tij664 Member
    Turlock, CA
    I kind of wish this was permanent as this would avoid locals without home charging clogging up superchargers. This would especially be a big help for charging while on a road trip in the usual areas where there are few superchargers but lots of people without home charging: LA, Fresno, SD, and Bay Area. I think the huge price difference would incentivize most people without home charging to charge off peak while those on a road trip would be willing to pay the higher peak rates.
  3. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Well, it's actually 12a - 9a, so cheap 9pm to 9am overall.
  4. AxlxA
    AxlxA Member
    Bay Area
    I dunno about you but PG&E has split charges for off peak like generation + delivery. So that $0.16/kwh is just part of it. The other part was $0.07/kwh so it ends up closer to $0.24 for me..... I can't wait for solar
  5. Randy Spencer
    Randy Spencer Active Member
    Alameda, CA
    Get a LOT of it. Trying to charge my 74kWh TM3 out of my 7kW system on any day that isn't in June-July is difficult
  6. The_Boy_Jordan
    The_Boy_Jordan New Member
    Bay Area, California
    Does anyone know what the current Supercharger prices are in the East Bay? We are looking at placing in an order once we get approved for the CVAP, but want to calculate how much we could be saving compared to gas with my current car. I guess you can't see the prices unless you own the car already.
  7. tij664
    tij664 Member
    Turlock, CA
    #27 tij664, Feb 26, 2021
    It’s usually 35 cents a kWh unless you charge off peak at a station with time of use rates. Realistically, the savings will probably be close to none in comparison to gasoline. The main data point I have to support this is that on road trips I usually spend on supercharging my Model 3 Performance what I’d normally spend in gas driving a 30 MPG car. If you’re comparing to a fuel efficient car like a Prius you actually would spend more money supercharging than gas.
    The only scenario where you’d come out ahead in savings compared to a gas car is charging at home with a favorable electricity rate.
  8. The_Boy_Jordan
    I appreciate the info! I know it depends on the area you live, but do you happen to know what the average cost is when charging at home?
    My current car costs on average about $0.15/mile. From what you provided about superchargers, I calculated about $0.09/mile, and with the average electricity cost in CA being about $0.20/kWH, I came out with $0.05/mile.
  9. Merrill
    Merrill Merrill
    Sonoma, California
    Do not forget about cost of ownership over say 10 years, not only saving on gas prices but maintenance, and of course helping the environment.
  10. The_Boy_Jordan
    Oh yeah of course! My current car is a WRX with about 73K miles, and I know I have some big maintenance costs coming up, so I want to trade it in before then. The car is definitely not environmentally friendly either with all my mods, so that will be another positive.
  11. tij664
    tij664 Member
    Turlock, CA
    Without knowing a ton of specifics let me confirm your math here. If you say your current car costs an average $0.15/mile then working backwards from a 3.25 a gallon price that’s about 22 MPG or so. If you assume let’s say an average of 280 Wh/mi consumption on your new car that works out to about .35/(1/.280) which is close to your estimated $.09/mile (the answer is 10 cents per mile if you round). At a rate of $.20/kWh at home then it would be .20/(1/.280) which is close to your $0.05/mile your figuring (the answer is 6 cents per mile if you round).
    If your car gets around 22 MPG as I calculated then yes, you’ll definitely be saving on fueling costs.
  12. The_Boy_Jordan
    Okay, thank you for confirming my calculations. My car gets about 20MPG and I used an estimated range of 325mi, because we were looking at a LR Model 3
  13. Randy Spencer
    Alameda, CA
    Range should be calculated at 80% of that 325 for travel. You only charge to 100% when you know when you are leaving the next morning, set it to charge all the way up the night before. Stopping to supercharge to 100% will double the time you spend charging.
    Also, realize that you won't even charge to 80% while enroute, you'll just charge enough to get you comfortably to the next supercharger. Often that means you are 5-15 minutes charging before getting back on the road. I am regularly done charging before I am done peeing.
  14. RayK
    RayK Active Member
    San Jose, CA
    That's a little TMI there Randy. :)
  15. Randy Spencer
    Alameda, CA
    Not that I take a long time to pee, just giving a sense for what it'll be like to road trip with a charger instead of a pump.
