As mentioned in previous posts/
threads, it was fixed in 2021.40.6 (late Nov/early Dec) and is still fixed in 2021.44.6, the latest version prior to v11. If its not working under the conditions below on the current general release versions, its regressed (potentially since v11), the vehicle is behaving different (fault?), or its not being defrosted properly.
But, after reconfirming on my current version (which may not be as up to date as some), defrost of the cameras definitely is working for me as can be seen below from a test this morning. Additional note, the car is plugged in (at 10A) but I do not believe it was when I initially tested this so do not think this is a factor. [update]checking my logs it was plugged in on the day that I previously posted that it was fixed but I still do not believe that being plugged in is a factor as it has cleared on other occasions when it almost certainly would not have been.
This morning, the car was pretty frozen up.
Following settings used to defrost
And 8 minutes later, its nicely defrosted and the windscreen and camera swept area would clear after a single wipe of the windscreen wipers. The camera vision area was mildly warm to the touch. The top of the camera housing (non vision area) remained frozen - its outside of the swept area. This was not the case prior to 2021.40.6 where these settings would not have cleared the camera vision/swept area unless sentry was on or, some reports of the seat heater being on - which without going over my past posts, I cannot recall ever getting to work.
View attachment 762112 View attachment 762113
