Can a RWD and AWD(P) please go on a drive together and report efficiency difference
Discussion in 'Model 3' started by Thomas Edison, Aug 2, 2018.
  1. Thomas Edison
    Thomas Edison Active Member
    Portland-ish
    Asking for a friend ;)
  2. apacheguy
    apacheguy S Sig #255
    So Cal
    I was just about to post a thread on this same subject ;)
  3. Thomas Edison
    Portland-ish
    I'll share writing credits with you.
    Everyone got that?.... Good!
  4. Ejl80
    Ejl80 Supporting Member
    Nj
    Oh and make sure you use the same tires, at the same PSI, and not draft any other vehicles... Also the drivers and cargo need to weigh the same amount please...
  5. S4WRXTTCS
    S4WRXTTCS Active Member
    Snohomish, WA
    I'm thinking it's going to take a few weeks to get efficiency data from P3D owners.
    Gotta give them time to come down from their high of 0-60 in 3.1/3.2 seconds, and snugging with the white seats.
  6. Thomas Edison
    Portland-ish
    If the 2 cars are side by side with a chain connecting them like nunchucks, then they have no choice but to give an accurate test.
  7. ewoodrick
    ewoodrick Active Member
    Buford, GA
    I think that it has already been show that the efficiencies are really close to each other. When at steady speeds that car should be really close.
  8. apacheguy
    So Cal
    Source?
  9. SageBrush
    SageBrush 2018: Drain the Sewer
    New Mexico
    Exactly. Very important to swap two tyres each too.
  10. SoCalGuy
    SoCalGuy Active Member
    So Cal & New York, NY
    Add a NonP AWD to the mix pls thanks
  11. SoCalGuy
    Oh and can you do with 18s no aeros, 18 with aeros, and 19s. If you have time, try the 20s too. Thanks
  12. Thomas Edison
    Portland-ish
    They "should" get the same, hence the title.
    Can't tell if this one is serious. All we really need is all things the same except the drivetrain. Different wheels can be calculated from there.
  13. SoCalGuy
    It was a half joke
  14. gilscales
    gilscales Active Member
    Long Beach, CA
    I’m in Long Beach, I have the rwd, 19” sport, line up the other cars and I’ll go
