Can anyone confirm if 245/45-R18 tires offer any rim rash protection?
insaneoctane
3,369
5,184
Southern California
Lots of talk about people trying different tire sizes, but I have yet to conclusively read if replacing the OEM 235/45-R18 with 245/45-R18 results in the tire sidewall extending slightly beyond the rim. Standard size tires offer ZERO rim rash protection because the rim is beyond the tire. I'm considering 245 *IF* it helps here...
dennisvab
229
165
Central New York
I may be wrong. But I think some tires just offer more protection in that same size than others. I’ve experienced this with my BMW X5 when replacing with the same size. I plan to replace with Continental DWS 06 tires in the fall, and I am expecting them to protect the rim better.
Reactions: LuPapa and KenC
Sky-Pilot
142
50
dennisvab is correct. Many newer tires have, for lack of better terms, a "lip" in which the tires fits into. I have the Conti DWS and it has a nice little lip and my rims are fully protected. Go to tirerack.com and look at a close up of the tire and look for a lip. Open the link below you can see the small lip or indentation that the rim fits into.
https://www.tirerack.com/tires/BigP...rch=false&fromCompare1=yes&sidewall=Blackwall
Reactions: dennisvab and KenC
KenC
3,278
2,993
Maine
That's the Messala spoke option.
And I would agree with Dennis and Skypilot that you need to look at the various tires on offer to see if they have a lip on the sidewall to help prevent road rash
insaneoctane
3,369
5,184
Southern California
your pic didn't work.
What size tire did you buy?
afadeev
691
615
NYC
Neither the +10mm wider tires, nor rim "rash guards" are EVER a match for a curb.
If your wheel intersects with a curb, the curb will win, every time.
Having said that, wider tires do improve lateral grip while cornering (at the expense of slightly increased energy consumption), and provide additional rim "buffer" during storage (if you swap for winter/summer rims).
a
Reactions: LuPapa
insaneoctane
3,369
5,184
Southern California
a
I wholeheartedly believe the small rim rash episodes on my Model 3 (not all by me) are a result of lightly touching the curb at very low speed while parking and would NOT exist if the tire touched first.
gilscales
1,684
1,897
Long Beach, CA
I changed my tires on the 19” sport wheels to a 255/40/19 (dws06 conti’s) and while 27” tall vs. 26.4” of the stock size my speedo is dead on now and comfort has improved as well as handling, I did tsk a 7 or 8% range hit so not too bad I guess and best thing is the rim rash protection, I know it works because my wife came home recently with curb rash on the sidewall and wheel was fine, no clearance issues, no rubbing at all and I highly recommend the 255 width in the same aspect ratio as stock for this car with its heavy weight
al503
161
71
Portland
The different tire manufacturers have different ways to measure their tires. One company's 235 might be up to an inch narrower/wider than a different company. With that in mind, I'd go on tirerack.com and look at the specs of the tires you're interested in. Compare the Section and Tread widths. FWIW, I'd definitely go with 245's instead of 235's. Despite another member stating it won't matter, it can give you a heads up, just slightly quicker, than a narrower tire. Not a huge deal on the 18"s but it'll also give you just a smidge more pothole/hazard protection as well.
gilscales
1,684
1,897
Long Beach, CA
Getting ready to buy, has anyone tried the wider tires yet? Which did you try (size and model)?
I bought the 255/40/19 tire size in Continental DWS06 and really, really like them, get curb rash protection, sidewall is a little taller so more comfortable than stock tire, my speedo is spot on now instead of reading 2 mph fast, handling is so much improved from the wider tire and higher load rating, only downside is after 16k miles on these vs. 17k miles on the stock Conti's is a slight range decrease from 246 wh/mi to 256 wh/mi. not to bad of a hit really, that is the tire in my sig and sidewall barely sticks out enough for some rash protection.
zhu-
custom title
Oct 24, 2018
882
752
NJ
Anybody know if there would there be any clearance issues if I were to put 255/40/19 on a wheel with a lower offset - or using 15-20mm spacers? I also want at least 245 or 255 for better pothole protection. I had 19's on my previous car with staggered 225 front and 255 rear and had so many bubbles on my front tires.
