Can anyone point me to a LiCo capacity vs cycles graph?
Discussion in 'Battery Discussion' started by dpeilow, Feb 5, 2015.
Tags:
  1. dpeilow
    dpeilow Moderator
    Winchester, UK
  2. stopcrazypp
    stopcrazypp Well-Known Member
    #2 stopcrazypp, Feb 6, 2015
    Here's a 2006 data sheet of a Sanyo UR18650F (likely close to what the Roadster used). Last page has a 500 cycle degradation graph. The link is not directly from manufacturer, but the datasheet looks legit.
    https://www.neuhold-elektronik.at/datenblatt/N5644.pdf
    According to the material datasheet here, the UR18650F series is a pure lithium cobalt cell (more modern cells tend to have a mix of lithium manganese or some kind of nickel based mix like NCA and NMC):
    https://panasonic.ca/PCS/OperatingInstructions/MSDS_IB-BC-003-02.pdf
    Edit, I dug a bit and found a newer 2012 datasheet for the same model number (although maybe updated a bit) direct from the manufacturer:
    http://na.industrial.panasonic.com/sites/default/pidsa/files/ur18650f.pdf
  3. dpeilow
    dpeilow Moderator
    Winchester, UK
    Great, thanks.
