Can anyone Recommend Rim Protectors for S/X?
Discussion in 'Model S' started by Reciprocity, Jul 19, 2017.
Tags:
  1. Reciprocity
    Reciprocity Active Member
    Chicagoland
    Looking for rim protectors that dont fly off at highway speeds. I have read so many bad reviews, does anyone have any experience with Evannex's slution or have another suggestion?
  2. berkeley_ecar
    berkeley_ecar S 90D (fully loaded) delivered 18 Mar 2017
    Berkeley, CA
    I have used the EVannex product with great satisfaction. Just be certain to clean the edges of the rims as instructed to get good adhesion. I've done a SF to LA round trip and lots of freeway trips more locally, with no problem. They paid for themselves the first week, as I began to develop my sense of the car's geometry and learned how to use the white guide lines that appear on the rear-view camera image when in reverse. Don't hesitate to contact me if you have further questions.
  3. DonL
    DonL Member
    La Jolla, CA
  4. Reekdog
    Reekdog Member
    Los Angeles CA
    I have Rim Savers on my car and they look and perform great! They're silver so you have to look closely to see them.
  5. Rbcnr
    Rbcnr Member
    New York
    @ reekdog, looks great.
    Have a link for the product? Thx
  6. strider
    strider Active Member
    NE Oklahoma
    Another reco for Alloy Gators. They stick out far enough that they will save the blade part of the wheel as they stick out beyond the rim. I looked at rim savers as they look a lot better but it looked ot me like if you rubbed a curb you would scrape the blade part of the wheel. We have "tested" ours numerous times and no damage to any part of the wheel.
  7. Reekdog
    Reekdog Member
    Los Angeles CA
  8. busaman
    busaman Member
    suffolk UK
  9. Dborn
    Dborn Confirmed
    Sydney, Australia
    If you want a rim protector to actually protect your rims, then Alloygators is the way to go. Mine took a real beating but did save the rims. This occurred mainly during my early days with the car when I was still not judging curbs accurately. Eventually they were looking so tatty that I removed them, but since I am now familiar with the car, I opted to change to Evannex's product. These are a little more decorative, a heck of a lot easier to install, but I suspect will not give much real protection. I think that one scrape and they will be erased off the rim. Nevertheless, I think they look good and add some pizazz, so will put them on again when they finally get damaged, probably when I change tires.
  10. Reciprocity
    Chicagoland
    Thanks for all the feedback. I am having a real issue even buying Alloygators..haha. Any suggestions for us in the US?
  11. ggr
    ggr Roadster R80 537, SigS P85 29
    San Diego, CA
    Just mail order direct from the UK. That's what I did. Easy and efficient.
    However I've stopped using them and no longer recommend them. One of them came loose and started thrashing the paint on the fender, the others started looking like they might give up too. I just try hard to park more carefully. Lines in the backup camera help a lot.
  12. Reciprocity
    Chicagoland
    Thanks all, tons of great advice. I really appreciate it.
  13. Reekdog
    Reekdog Member
    Los Angeles CA
    Regardless of which product you choose, the end result is based upon how well you clean the surface of all debris and contaminants as well as prepping each wheel for the ones that require adhesive to adhere. I've had no issues so far and pressurewash my wheels once or twice a week.
  14. busaman
    busaman Member
    suffolk UK
    im the same i have heard of one coming off the bead and doing damage, but was more than likley not fitted correctly in the first place or had impact damage and came appart i have tried and its very hard to get them off with the tyres inflated.
