Hi all,
Like an idiot, I parked on snow on my sloped driveway and my car slid, tearing the cable out of my HPWC and cracking my charge port.
I got the charge port replaced at my SC, and they kindly gave me a new HPWC cable - but the inside of my HPWC has some damage I need to fix. Nothing major, but there are a few parts I just don't know the wiring for.
I need to know what wires go into connector CNA6 - it took most of the damage.
I've got a loose red wire coming from CNA11 I don't know the destination for.
I'm not sure where the ground strap wire goes from A4
I've got the screw terminal block from CNA5 and will replace it, but I don't know which wires went where into it - it got torn off the board, then the wires got torn out of the connector, so it's a mystery unless someone can send me this info.
I don't know where the 3 small wires from the charge plug go - gnd and the 2 data lines. I'm assuming they go to CNA5, but not sure which goes where in.
The unit looks fine otherwise, and it did a good job - not a spark or anything - it and the car shut down gracefully. My only complaint is that the car was stuck in the middle of the street until I was able to wrench the charge cable out of the port. Sometimes I wonder if the car should have a "I know the plug is in, but I REALLY need you to drive and I promise it's OK" mode.
Anyway, thanks to anyone who can help me get this going again. Charging off my UMC like a caveman until I get this sorted.
