I ran into a new issue I've never saw before. New S75D, new MCU. It charging along at 48A happily. I had it set to 100% for a morning trip. Once it got to ~95% I lowered the set SoC to the usual daily limit which was below the current SoC as I've done before on our other Teslas no problem. The car stopped charging ok, but then threw a charger error and red light around the charge plug. Tried the charger on another car, worked just fine even at 80A but the new S75D kept throwing the same charge plug error. I left the car locked for 15 minutes, came back, charging fine. Tried the same thing, lowering the set charge point to less than current state of charge, got the same error!
Can someone with a new MCU car check what happens on your end when you lower the set charge below current state of charge. The charging should stop of course, but then does the error show up?
