This should all have been explained to you during design phase.I have one Powerwall in the garage and 40 panels on the roof.
The installer told me my A/C could not be connected to the Powerwall.
So when we do not have power - we also have no A/C.
Is that a true statement.?
Thanks
With one Powerwall, that is almost assuredly a true statement.I have one Powerwall in the garage and 40 panels on the roof.
Thanks
agree, and even if a AC is being run, he probably wouldn't be cool for very long since many units will draw 4 KW or more.With one Powerwall, that is almost assuredly a true statement.
He could get a few hours.agree, and even if a AC is being run, he probably wouldn't be cool for very long since many units will draw 4 KW or more.
He could get a few hours.![]()
Yep, but I was responding to the post that said but if you could get it started, how ever that happened,.... But with the new 2.1 PW with 50% more output to 7.5hw, maybe he might have a little better chance.No, he could not, you are confusing the OP. Its not connected, so he cant get "any" hours, and it was not connected because the start up was not supported by 1 powerwall, meaning trying to start the AC would shut down the powerwall.
So, no, in his situation with 1 powerwall, he could not have had it connected, nor get "any" hours.
I do not have it, and it was explained to me, but my friend has the same installer and system with less panels. He says his A/C runs on the PW. I don't believe him
Just go trip the main breaker, and am him turn on the ACok all good info, I am calling my friends bluff, and saying he is wrong. he has one PW, and a small house. he is very challenged when it comes to technology. thanks team for the replies.
I'm in a similar situation. My 2 Powerwall whole house backup was supposed to be able to run my Carrier heat pump but Tesla didn't catch that their soft start device isn't compatible with the reverse run compressor. My compressor will only start if the solar is producing. Since the batteries quickly recharge without the AC running and the Gateway then commands the solar panels off there is only a small window to start the compressor. It is a PITA.Site with 2 powerwalls (10kW solar) can run the whole house including AC during an outage - however - my 3 ton AC has a really serious startup compressor kick that will trip the powerwalls at night. I can run during the day because the solar provides the additional support. I have to shut down my AC at night. It is a known and acknowledged issue that I was initially not going to be allowed to do a whole house backup - serious technical discussion with my engineer and it was allowed when I clearly accepted the operational limitation. My compressor will not accept the the usual soft start electrical modification. I should have thought to simply increase my PW install to 3 instead of 2. Brain fart on my part.
Go over after sunset and ask him to turn the main breaker off. See what happens.ok all good info, I am calling my friends bluff, and saying he is wrong. he has one PW, and a small house. he is very challenged when it comes to technology. thanks team for the replies.
