Can I see photos of your HPWC installed on a cinderblock wall?
Discussion in 'Model S: Battery & Charging' started by MelaniainLA, Apr 10, 2017.
  1. MelaniainLA
    MelaniainLA Member
    Los Angeles, CA
    We live in an apartment and the electrician who is installing our latest-generation HPWC is asking us how we'd prefer the setup to look like (re: the routing of the electric conduit for aesthetic purposes) on the cinderblock apartment garage wall.
    Can whose of you who have a latest-generation HPWC installed against a cinderblock wall (such as those found in apartment garages) please post photos of your setup so I can get ideas? Appreciate it!!
  2. miimura
    miimura Active Member
    Los Altos, CA
    This is a typical common area installation I found using Google image search. Photo is from Edmunds. The disconnect is typically required if the Wall Connector is configured for more than 60 amps. If the disconnect is not needed, then it would look the same except without the giant gray box.
  3. wycolo
    wycolo Active Member
    WY
    The separate disconnect box is highly recommended both for safety and convenience. After all, that HPWC is just a plastic thingy and what are you gonna do when you find it all hot n pussy with smoke percolatin . . .
