Can I use Homelink to replace my garage door FOB?
Discussion in 'Model S: User Interface' started by Seegem, Mar 27, 2013.
  1. Seegem
    Seegem Member
    New York City
    Hi, my garage door (for my condo building) uses a FOB / tag. It looks like a small EZ pass (about the size of a credit card but about 1/3 inch thick). It's meant to be adhered to the inside of the window, near the rear-view mirror (just like EZ Pass), however the coating on the Model S window prevents it from reading (I have to open the sunroof and hold the tack against the roof). This is fine, but, I was wondering if the Homelink can be programed to mimic the tag signal? Technically, and theoretically, this should be possible. Has anyone any info / success with this?
    Thanks!
    Mark
  2. mknox
    mknox Well-Known Member
    Toronto, ON
    I don't believe so. I think the tag you mention is a passive device whereas Homelink is a transmitter used to mimic typical garage door opener RF transmitters. We use passive tags for doors and gates where I work, and my understanding is that they receive some sort of RF signal and resonate back at a certain frequency that the mechanism recognizes. There is no battery or active transmitter in our gate control tags.
  3. Seegem
    Seegem Member
    New York City
    Yes, that's exactly how they work. I'm wondering if the response signal can be mimicked by an active device. I'll do some research into the frequencies used as well later this week and report back.
  4. dtich
    dtich #P708
    Los Angeles
    you could try mounting it behind the smoked plastic nose on the front grill....?
  5. dychen888
    dychen888 Member
    Phoenix
    They had this issue with certain vehicles when EZ Pass first came out in NYC. The solution was to get a front plate mounted ez pass.
  6. Seegem
    Seegem Member
    New York City
    Thats precisely what I'm doing with my EZ pass and garage door fob :)
    - - - Updated - - -
    No front license plate :)
  7. PaceyWhitter
    PaceyWhitter Member
    Columbus, OH
    I assume the fob contains an rfid chip, if so there is no way for homelink to mimic it.
  8. MarkR
    MarkR Member
    N. Scottsdale, AZ
    Because the windshield of the Model S blocks radio waves, I mounted the EZ Pass to the inside of the nosecone with some velcro tape - worked nicely!
