Can my regular shop replace the front disk pads?
Discussion in 'Model S: Interior & Exterior' started by Pmacafee, Dec 27, 2016.
  1. Pmacafee
    Pmacafee Member
    San Francisco
    I searched this forum but could not find anything about having another shop replace the front pads. I have my regular shop replace the tires when needed and the last time they pulled the wheels off, they said I needed brake pads but did not want to do it because a special tool was needed.
  2. jelloslug
    jelloslug Active Member
    Greenville, SC
    Yes, the friction brakes are conventional and the pads can be changed by any mechanic.
  3. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    They are regular Brembo brakes. Normal disc brake procedure. No special tool needed.
    1. Remove the 2 brake pad pins
    2. Gently push piston in
    3. Slide brake pad out.
  4. Dakkor
    Dakkor Member
    Lachenaie, Quebec, Canada
    Does anyone know the Brembo part numbers for pads and disc? I work for a Autopart supplier and we sell Brembo parts under our brand name... I have a huge discount so this would be nice to have..
    edit: not on Brembo website.. meh.
  5. JPP
    JPP Active Member
    SF Bay Area, CA
    ...curious, how many miles, what model, how do you drive, regen setting, etc...i don't know too many Tesla S owners replacing pads.
  6. mrElbe
    If I ever need new pads, I'll get them from RockAuto. They have listings for Economy to Performance, not Brembo though. I don't expect to replace pads soon as with Regen there is minimal usage.
  7. Dakkor
    Dakkor Member
    Usually it take 3-5 years for a model to be available at OEM Retailer. I work for Napa and Tesla is not listed yet.
  8. mrElbe
    But RockAuto has a full listing.
  9. jelloslug
    Greenville, SC
    There are many options for brake pads for the Model S since it uses calipers that are common with many, many other cars. I'm sure that lots of the parts in the S are off the shelf parts that are readily available.
  10. jelloslug
    Greenville, SC
    Here is a video of the pads being changed on a car with the exact same type of Brembo calipers that are on the Model S:
