Hey gang, tried to find specific technical info on this, and zero luck. I'd like to know how my car works. Since the rear motor is a permanent magnet one (a better motor), and the front an induction one, I assume the car is RWD unless it needs front traction, right??? Or does it send 'x' percent of traction to the front axle all the time (even if not needed), like FWD-based Audis (and other vehicles) do?
And finally, what's the deal with traction on each axle? Do the electric motors act like an open differential (traction on just one wheel), or like a limited-slip differential (traction in both wheels)? And do both front and rear axles behave the same way (both LSD, or both open), or not?
That's what I want to know gang. Or allow me to ask the same question in a more practical way, in case somebody already tried that : If you floor the throttle on a wet or sandy street, would the car leave 2 tire marks (1 front/1 rear), 3 tire marks (2 front/1 rear, or 1 front/2 rear), or 4 tire marks (all 4 tires have traction)? That'd also tell me what I need to know. Thank you.
