Can someone Calibrate Autopilot 2.0 on a Model S Facelift
vladi
20
Phoenix
Calibrate?
You shouldn't have to do anything except drive it for a day the first time you get it.
It doesn't seem to be able to. Sometimes it starts detecting the lanes, cars, and speed signs when I turn the car on(if it hasn't been on for a few hrs) but that lasts a few seconds and then it disappears.
Reactions: D.E.
animorph
2,143
1,538
Scottsdale, AZ
Haven't heard of anyone doing it by themselves. The SC can do it if necessary. They like you to wait about 200 mi, but you should be calibrated after roughly 50 mi. Sounds like you have problem that requires a fix.
Reactions: croman
vladi
20
Phoenix
Thank you for your reply. What is SC?
vladi
20
Phoenix
Just some parts on the suspension. No sensors or cameras. Even the front bumber was good. I don’t even get an error on the screen. We had all the cables and connections checked and everything is connected and working properly.
MarcusMaximus
3,789
16,514
Los Gatos
I’m thinking you’re out of luck unless you get the car recertified. Calibrating the cameras to match what the AP networks expect would likely require intimate knowledge of the network itself that nobody here(or outside Tesla) has. Best I can think of that you can personally try doing it just randomly jiggle the front cameras to see if you can clear the issue.
Keith909man
412
750
Tacoma wa
I had this happen to my 2017 S. first the auto windshield wipers stopped working (wouldn't turn off unless I placed it but in manual) then it stopped reading the lines and traffic.. Thought my calibration was messed up. took it to a SC and they told me the front facing camera stopped working and had to replace it. Hints why the auto wipers started acting crazy. So if your car saw the lines before and then stopped, most likely your front camera gave out.
NOTE: auto pilot 2.5 uses a different front camera from the 2.0. SC didn't even know this until they installed a 2.0 camera and it didn't work so they had to order a 2.5 version
vladi
20
Phoenix
Thank you. I will give that a try. I know there are a few cameras. On the facelift the front cameras are on the windshield only(Correct)?
robby
642
361
Andover, MA
The instrument cluster will only show road lines and cars around you if the radar and camera agree on the state of the world. I would definitely calibrate the radar before replacing the camera.
Here are instructions for the non-facelift model. You can probably do a similar procedure on the facelift model once you get access to the radar behind the bumper cover. Front Radar Calibration
appleguru
952
1,688
US
Silly, but worth mentioning as it seems to get disabled on my car sometimes inadvertently... make sure you have autosteer and auto lane change enabled in your driver profile.
Yaro
283
138
Sacramento
Did you remove the radar? If you didn't remove anything, it will calibrate itself within a 1,000 miles regardless.
I replaced a radar on an AP 2.0 car and it some how programmed itself and calibrated and autopilot works now. Just have to drive for a good bit.
vladi
20
Phoenix
Thank you for your response. Do you know where the radar is located on the facelift? I don't think it is on the same place as the first model(or as it is shown on the link you provided me with).
