Can Tesla remotely do DX if car is dead
Discussion in 'Model X: Battery & Charging' started by jerseygirl18, Feb 17, 2021.
  1. jerseygirl18
    jerseygirl18 jersey girl
    Delray Bch/Chicago/Brklyn
    my car is dead like locked & won't preform any task! Can Tesla remote service help or is this a visit by Road Serv necessary?
  2. ElectricOrgan
    ElectricOrgan Member
    Does it respond to the app on your phone?
  3. doghousePVD
    doghousePVD My grandfather’s car
    New England, USA
    If everything is dead, it is probably the 12V battery in the frunk. You can jump start if you have access to another battery. If the car won't respond to your phone or electronic key, a service tech visit is required.
    You can open the frunk by removing a plastic shield on the front and pulling the cords. Google for details.
    Google how to find the battery, and give it 12 volts power. The car should respond. Then you can charge the car.
    You probably will have to replace the 12 v battery soon, but at least you can get in, charge, and maybe drive.
  4. mbp11
    mbp11 Member
    SF Bay Area
    Cross positing, sorry
    I have recently found that I have a new hobby- showing local Tesla owners how to resuscitate their dead Teslas if they let the main battery (and subsequent 12 volt battery) discharge completely. Have helped several people on the Tesla Forum and even one of my associates who thought he could charge his 2019 Model S up to 100% and then fly to India for 3 weeks (and got stuck there for 6 weeks with the pandemic and cancelled flights. We knew this was going to happen!). Each model Tesla has different challenges. I am surprised more owners have not learned what to do when the Triple A guy
    The strategy is the same for each car- have the main Tesla battery charger ready to go, get access to the 12 volt battery or the hot leads in the fuse box, jump the 12 volt battery until there is enough charge to open the charge port, and charge the car!
    For the Model X (my car), you need to pull the plastic cover off of the front left side of the car and get access to the two pull cables labeled 1 and 2, release them sequentially, then open the frunk. Pull the housing off the flat part in front of the windshield and just behind the frunk, pop the fuse box in the left side (the battery is deep behind the frunk, you cannot get to it) and locate the hot lead and plug the hot lead of the charger to that and the ground of the charger to chassis, turn on charger and wait. When the car wakes up, open the charge port and charge.
    (I also suggested leaving the 12 volt charger attached for a while to get the 12 volt battery up a little, until there is enough main battery charge to continue to charge the 12 volt).
  5. mbp11
    mbp11 Member
    SF Bay Area
