Can the Model Y power a tailgate setup?
CharlieP-SC
6
4
Sumter, SC
For tailgating, I’ve used a small generator to power an LCD TV, an AppleTV and a small, portable PA system to amplify the sound. I then use the ESPN app to stream live sports. Can the Model Y power that much equipment using a power inverter or will I still need my generator?
CharlieP-SC
6
4
Sumter, SC
Still need the generator. The 12 volt system is not designed for much load.
Thanks! That’s what I thought. I’m hoping that if I replace my tailgate TV with a “smart TV” that doesn’t require a separate streaming device and has enough output volume to eliminate the need for an external amp, the car can handle it (just powering the TV and nothing else).
Bryceg
10
6
Seattle, WA
I believe that 12v outlet is only rated for a 12 amp load, so 144 watts of output plus some percentage loss on the inverter. Tesla manual does not recommend using the outlets with inverters though, may be safer to just use a generator anyway.
