I’m about to have a wall charger installed, I am trying to decide between the Tesla wall charger or the ChargePoint charger. The ChargePoint charger is a little more expensive but it can charge any electric vehicle. I am pretty much a Tesla fan boy but Teslas poor service at times tries my patience so if I ever decide to go with another brand (Assuming anything comparable ever pops up) I want to make sure I don’t have to buy a different wall charger. Are there any adapters for the Tesla charger and would it even charge another EV or does it have a built in detector that won’t allow none Tesla vehicles?
Yes you can with an adapter. You can get one on ebay. I use it to charge my wife's Chevy Bolt. Works on any level 2 Tesla charger. Will not work with Superchargers! TeslaTap 40AMP - Tesla compatible J1772 adapter | eBay
We use our wall charger with an adapter for my girlfriend's Fiat 500e. It can't take advantage of the 60 amp circuit, but it charges full in under 2 hours.
this is wrong. tesla to J1772 adapter: https://www.amazon.com/Lectron-Tesla-Charger-J1772-Adapter/dp/B07V7V2QT8
In addition to the adapters, it's possible to replace the entire cable assembly with one with a J1772 plug. This might be preferable to using an adapter if you replace a Tesla with a non-Tesla EV; however, it would be more hassle to install and it would probably be more expensive. Also, if you replace the car far enough into the future, it's conceivable that the Tesla Wall Connector would be on its last legs, or there might be features in newer J1772 EVSEs that you'd want. Thus, replacing the EVSE might make sense in this scenario, although that would likely be even more expensive. You could probably re-use the wiring from the breaker box to the EVSE, though, so installation costs would be low. Currently, Tesla's J1772 adapter is $95, and one comes with every new Tesla sold, whereas third-party adapters to let non-Teslas charge on a Tesla EVSE cost in the $200-$250 range. Of course, that might change in the future. Also, be aware that Tesla has recently discontinued its Gen2 Wall Connector in favor of a Gen3 model. There are various discussions on this forum about this shift. In brief, the Gen3 unit has an ~18-foot cable, vs. a choice between ~8-foot (IIRC) and ~24-foot cables for the Gen2; the Gen3 maxes out at 48A, whereas the Gen2 can provide up to 80A (but both can be dialed down below these limits, and often are, to match what's reasonable given your car's and house wiring's capabilities, and all current-production Teslas max out at 48A or lower); and the Gen3 adds new WiFi features. If you prefer the Gen2 features, you may need to scramble to find one; I don't know how much Gen2 stock is left. Given the wide variety of third-party J1772 EVSEs, you can probably find almost any mix of features you want in them, except of course for the Tesla plug and interoperability with Tesla EVSEs (for load sharing, etc).
A note for EU-located readers/owners: in Europe a Tesla wall connector uses a standard Type 2 connector, which will fit and charge any EU Tesla (of course) AND any other EV vehicle with a Type 2 socket.
Same as in AU. Plug will fit, however communication protocol is different. Gen 1 chargers have a Legacy mode (Dip 2 switch down) which enables all Type2 cars to charge. Early Gen 2 chargers also have legacy mode, but this was removed some time in 2019 and no longer mentioned in the manual. Dip 2 is still there but does nothing. Don't think we've seen Gen 3 outside the US.
I recently picked up a Kia Niro and bought this. I’ve read on Amazon that this charger is destroying their Tesla charger(Meaning their charger would no longer work). I used it on the Niro and went back to see if it would charge my Tesla and it worked fine. Did you have an issue with this charger?
