Can we get bolt and nut torque specifications?
Discussion in 'Model S' started by cab, Nov 13, 2016.
Tags:
  1. cab
    cab Member
    Grapevine, TX
    So if We want to work on our cars ourselves, beyound changing wheels, is it possible to get the various torque specifications for thinks like suspension component bolts, etc? I just happen to be looking for specific stuff around suspension components, but really the question applies across the board. Obviously Tesla doesn't publish repair manuals for consumer use and isn't terribly DIY friendly. Anyone or any tips?
  2. jaguar36
    jaguar36 Active Member
    NJ
    Unless you live in Massachusetts where you are able to access the repair manuals, then nope!
  3. Btr_ftw
    Btr_ftw Court Jester
    Mass
    upper control arm ball joint to knuckle torque 60NM
    sway bar link to the knuckle torque 70NM
    sway bar to sway bar link 70NM
    tie rod end to knuckle torque 103NM
    forward lower control arm to the subframe 130NM
    rear lower control arm to the subframe 130NM
    shock absorber to the lower control arm 140NM
    lower control arm ball joints to the knuckle torque 195NM
    Top 3 nuts that hold shock to tower 39NM
    • Helpful x 2
  4. xavier74504
    xavier74504 Member
    France
    Lug Nut Torque Spec: 129 lb-ft (175Nm)
    Does somebody know the torque spec of the TPMS locking nut/ring?
  5. dark cloud
    dark cloud Member
    BC
    #5 dark cloud, Oct 1, 2018
      • Baolong TPMS: Torque 5 Nm.
      • Continental TPMS: Torque 8 Nm.
    • edit: actually this picture looks important:
    • Informative x 2
  6. xavier74504
    xavier74504 Member
    France
    Thank you very much.
