Can you install 21-inch Arachnids staggered wheels on a 75D that came with 19" standard wheels?
Discussion in 'Model S: Driving Dynamics' started by Jlwine, Jun 15, 2018.
  1. Jlwine
    Jlwine Member
    Indianapolis
  2. AMPUP
    AMPUP Member
    Dunn Loring, VA
    Yes... you just have to select the 21 option when relearning TPMS and you should probably get the car re-aligned after installation.
  3. P85_DA
    P85_DA Supporting Member
    Yes but you will lose range ~15% ..since you have smaller battery that will suck ...although 21s look the best on an S :);)
  4. Jlwine
    Jlwine Member
    Indianapolis
    I'd expect some range loss--but is it really as much as 15%, how come so much?
  5. P85_DA
    yes its that much sometimes more... i had 21s on both my S (P85+, P85D) and consistently saw that drop off driving over 80k miles.. on tesla website that is what they state as well.. its due to increased weight of wheels/tires .. greater rolling resistance.....since you have a smaller battery and live in area where roads probably not as good maybe good option is look at Tsportline 20s .. they look nice and are lighter... the stock 21s are just really heavy.. although they do look nice :eek:
  6. CUBldr97
    CUBldr97 Member
    MD
    not to mention staggered set up will loose ability to rotate the tires...
  7. Navsarin
    Navsarin S100D Red Rocket
    Canada
    Arachnids are supposed to be the lightest of the 21” sets no?
    I know I know...it’s also about rolling resistance lol.
  8. P85_DA
    They are not as light as the 19s :(...if you don’t drive far than it’s probably a non issue ..the issue than becomes like other poster mentioned u can’t rotate ..I found on my P85D I was getting 15k miles max in my staggered 21s. 21s are also limited in tire selection ...my X with 22s is cheaper to find tire replacement with more selection ..that said I would never put 19s on my S :eek:
  9. gdh66
    gdh66 Member
    Portland
    The standard 19s weigh about 35# with tires while the 21s (non-arachnids) weigh about 65# with tires.
  10. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
    A lot of misinformation has been posted here :cool:
    My current Model S with 21" Arachnid wheels gets the same range compared to my 19" OEM wheels.
    The Tesla forged 21" Arachnid wheels are lighter and stronger than both the 21" and 19" OEM wheels.
    For the record: The Tesla Model S Wheel Guide
    19" Model S Base Wheel
    • Size: 19X8.0"
    • Weight: 29.5 lbs
    21" Turbine Wheel
    • Size: 21X8.5"
    • Weight: 21x8.5" = ~35.2 lbs, 21x9.0" = ~38 lbs
    21" Arachnid Wheel
    • Size: 21X8.5" front, 21X9.0" rear.
    • Weight: 21x8.5" = 27.85 lbs, 21x9.0" = ~ 28.75 lbs
    • Informative x 4
  11. FlatSix911
    Silicon Valley
    I forgot to mention the Arachnids look great too... :cool:
  12. Astraviel
    Astraviel Member
    Vancouver, BC
    I don't think that's true. I recently went from OEM 19" to AG F221 20" and carrying those 19" with tires was definitely more than 35 lbs each. They felt slightly heavier even than my AG F221 20" with tires.
  13. Yinn
    Yinn Active Member
    Behind you
    This is the correct answer. We have a MS60D that came with 19” wheels. The SC gave us and installed our 21” Staggered Arachnid wheels through the referral program. So they are officially supported and fit. We did not notice a significant decrease in range or increase in consumption over the last 10,000 miles.
    This is a drastic difference compared to our X which increases consumption and loses 8-10% of range going from the 20s to 22s.
